05-13-2022, 12:16 PM | #1 |
Drives: 2022 1SS Rapid Blue, 6 speed manual Join Date: Feb 2022
Stopping Brembo Dust on the Rims
Anyone know of a product or procedure out there that will keep the Brembo dust from sticking to my rims. Wash it drive it 10 miles and the rims look just as dirty as before I washed it. Help please.
05-13-2022, 12:20 PM | #2 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
If you are not tracking your car, then install the PowerStop Z26 pads.
That's what I, and tons of others on here did to reduce (by 75% or more I'd say) the brake dust. There are things you can put on the wheels to help reduce build up or clean them easier, but pads are the best solution for a street driven car.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
05-13-2022, 12:35 PM | #3 | |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
You will get reduced braking between the two pads but as said with a street car you won't notice that difference. You just can't track that Z26 pad. |
05-13-2022, 12:44 PM | #4 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
The cleaner and slicker you can make your wheels, the less likely dust will stick, and the easier it will be to rinse off.
Here's my thread on wheels off detail with ceramic coating. https://www.camaro6.com/forums/showthread.php?t=505584
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
05-13-2022, 12:47 PM | #5 |
Drives: 2SS 1LE Join Date: Oct 2011
My wheels are the same color as brake dust. Win!
Seriously, if this is a concern, ride a bike.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
05-13-2022, 12:52 PM | #6 |
Thanks for the help guys. WhiteMale, I hope that ZL1 comes in for you.
05-13-2022, 12:55 PM | #7 | |
I don't need track pads, I removed them myself. Problem solved.
05-13-2022, 01:35 PM | #8 | |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
05-13-2022, 01:42 PM | #9 |
One more for the Z26 pads. Did the swap on the SS at 1000 miles. Night and day. It was nice not wiping that shit up every/every-other night.
2017 ZL1 A10 2017 2SS M6: (SOLD) || 2014 2LT Convertible: (SOLD) || 2010 2LT M6 Supercharged:(SOLD) || 1987 IROC-Z 5.0 M5: (SOLD) |
05-13-2022, 01:43 PM | #10 |
05-13-2022, 01:44 PM | #11 |
05-13-2022, 01:47 PM | #12 |
I have ZERO issues stopping my SS with the Z26 pads and rotors. Honestly can't tell any difference between the Brembo pads and the Z26 pads for how I drive my car. As others have said... "If" you track your car then fine I get it, but if you don't, putting up with all the brake dust is kind of foolish when you don't have to. For the weekend warrior, spirited driving their Camaro on public roads, you will never outdrive the PowerStop brakes.
05-13-2022, 02:03 PM | #13 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
for those that have the drilled and slotted rotors question. When going pretty fast and u push the breaks hard do you get a noise almost like a grinding? Wondering if I installed mine correctly. And the power stop for the win here too
05-13-2022, 02:10 PM | #14 |
I get no noise at all with my PowerStop drilled and slotted rotors with the Z26 pads. I know there was markings for which wheel they went on when I bought & installed them.
