05-03-2022, 10:25 AM | #1 |
1LE OEM Alignment
Had mine checked for the first time this morning and some were pretty far off for a straight-line car.
Front and rear camber didn't change much. Caster is fixed at 7.5/7.8 Front toe, total toe and steer ahead changed a lot Rear toe and total toe changed a lot thrust angle changed .03 In summary, it's definitely worth having this checked out.
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. 1116/967. 1.35/9.25/151 at 3500 ft. (only one pass) 15" conversion/MT ET Street R 325/50R15. Last edited by JSH; 05-03-2022 at 12:30 PM. |
05-03-2022, 10:32 AM | #2 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
caster is not adjustable and is factory set...
05-11-2022, 09:52 PM | #3 |
Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
What settings did you go with?
I should probably get mine check with the new tires. Any recommendations? Sent from my moto g(7) power using Tapatalk
05-14-2022, 08:18 AM | #4 |
My alignment:
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. 1116/967. 1.35/9.25/151 at 3500 ft. (only one pass) 15" conversion/MT ET Street R 325/50R15. |
05-14-2022, 08:43 AM | #5 |
Thank you
05-14-2022, 11:42 AM | #6 |
Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
You have a 1LE wing and you call it a straight line car? . You know that’s like two ends of the spectrum right?
05-14-2022, 12:34 PM | #7 |
Drives: 2020 SS 1LE Join Date: Aug 2020
If you’re tracking your car, you’ll want more negative camber.
05-14-2022, 01:25 PM | #8 |
Of course. I haven't really looked into it, so I don't know if removing the wing is an option and I'm not sure I would do it if it was.
'20 ZL1 1LE A10.
05-14-2022, 01:34 PM | #9 |
I only mentioned the wing because I didn’t you know had a 1LE. Everything on your car is against straight line; wheels, tires, shocks, springs, front end and front end aero etc etc.
05-14-2022, 04:40 PM | #10 |
I assume you're referring to stock. I've changed wheels, tires, rear end, front end, and springs and shocks are next.
'20 ZL1 1LE A10.
05-14-2022, 05:20 PM | #11 |
05-14-2022, 06:37 PM | #12 |
I do have Shadow grey and would like to swap but I'm not certain about the fit up.
'20 ZL1 1LE A10.
05-14-2022, 08:56 PM | #13 | |
Take care bud |
05-19-2022, 09:22 PM | #14 |
IYAOYAS
Drives: 22 1LE 2SS M6 Riverside Blue Join Date: Mar 2018
Not trying to jack the thread, but just went to get a track alignment done today and this is the best a speed shop could do with no drive-on lift. They depend on 4 post lifts only and some dollies under each wheel.
Does the diagram look remotely close to a track alignment? I gave them the performance track prep sheet. But couldnt get the fronts to -2.0 without flipping the struts.
2022 Riverside Blue Camaro 2SS 1LE/ PDR
2020 Red Hot Camaro 2SS 1LE/PDR /Sold 2018 black Camaro 2SS M6 Redline Edition/Traded 2016 summit white Camaro RS V6 M6/Traded |
