04-18-2022, 02:04 AM | #1 |
Drives: 2003 Monte Carlo SS SLP, 2022 ZL1 Join Date: Aug 2021
Waxing hood Extractor
Sooo making a longer story shorter. I flew in to take delivery (last month) from a dealership which was over 300 miles away from me...The drive back was no cakewalk having to drive a brand spanking new unit through a heavily sanded city, briefly, through agricultural areas, and out of cow towns before I made it the freeway. Everything was great until I hit rain sleet and snow over the grapevine in sub 40* weather.
Anyway, when I finally got the car home, it looked like shit so I called a mobile detailer to put in work...My guy did a fantastic job, 2 foam baths, clayed, handwaxed and sealed; never touched it with a towel as it was air dried to avoid micro-marring...One thing I advised him NOT to do was wax my exposed carbon extractor. I did so simply on the strength of the manual stating not to do so on any ZL1 extractors...(more to this later after replies).... So my question is, how many actually wax your extractor? Or clay it? My detailer mentioned his personal friend has the same exposed carbon weave extractor but on an ZLE and his looks like shit because there are so many scratches and swirl marks. This make me curious on how many actually follow this guideline... Thoughts? |
04-18-2022, 02:51 AM | #2 |
Drives: 2022 Wild Cherry ZL1 1LE Join Date: Mar 2021
Hello there! I actually just covered my ZL1 1LE's whole painted areas + carbon fiber areas with Expel (ok I'm sure someone will chime in to say this product is utter shit haha).
You got me nervous with your comment above about not waxing the extractor, so I checked the user manual, and here is what it actually says: Hood Extractor For the Camaro High Performance vehicle, see the Camaro High performance supplement. It is not recommended that the air extractor on the SS Performance Package be waxed, as it will change the gloss level of the surface. In addition, care must be used when waxing around the air extractor. If a small amount of wax is applied to the extractor it can create an irregular appearance in the surface of the panel. The air extractor may have vent screens in the openings. Keep leaves or other debris out of the vent screens. A picture of the SS 1LE air extractor is also provided. Given this, I believe the warning is purely for the plastic trim that comes on SS 1LEs, and not the carbon fiber extractor on ZL1s. Geoff |
04-18-2022, 03:01 AM | #3 | |
What am I missing here???? |
04-18-2022, 03:05 AM | #4 |
Forgive my sideways pic. Never happened to me before but my comment still stand......am I not in the ZL1 section? Wtf is going on???
04-18-2022, 03:34 AM | #5 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
I don't see why you can't polish and wax the hood extractor just like any other painted surface. The exposed carbon version has clearcoat over it. Been doing it for years, never had a problem.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 Last edited by swisstyphoon; 04-18-2022 at 03:49 AM. |
04-18-2022, 03:37 AM | #6 | |
Also what's your definition between polished vs waxed? I understand how carbon is covered..... |
04-18-2022, 03:59 AM | #7 | |
In short, polishing is for removing light swirls and scratches while waxing is for protecting your paintwork and giving your car that glossy look.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
04-18-2022, 06:31 AM | #8 |
Drives: 2020 Camaro ZL1 1 LE Join Date: Mar 2021
Mine is ceramic coated plus I use a topper (turtle wax ceramic spray coating). I’d worry about UV light damaging it if you left it with absolutely no protection (same goes for rear wing)
04-18-2022, 07:14 AM | #9 |
Drives: 2022 ZL1 Join Date: Dec 2021
Wax It
04-18-2022, 09:59 AM | #10 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
I read that in the manual too when I first got the car, and I still had no hesitations in buffing the scratches out and ceramic coating it.
04-18-2022, 10:10 AM | #11 |
04-18-2022, 10:14 AM | #12 |
Drives: Chevy Camaro ZLE Join Date: Mar 2022
It seems like they are talking about the satin black wrap. I have polished and applied a coating on top of mine and it looks great.
04-18-2022, 10:22 AM | #13 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I concur it's the vinyl wrap not the carbon fibre that the manual refers to, same as the hood wrap on the 1LE
04-18-2022, 10:52 AM | #14 |
Thank you Al Oppenheiser!
Correct. The 1LE satin wrap has its own special care requirements.
As to the OP's question: A top shelf self-healing Paint Protection Film is the best way to go. A top shop will remove the emblems, wrap and tuck the film, and replace emblems so there are no visible seams. Then some hydrophobic coating (if needed) and you can pretty much do anything after that and it will look fantastic ... which for me is 4-1/2 years of bliss |
