04-15-2022, 02:14 AM | #1 |
How long do the Goodyear F1 last
On my previous post I stated I was gonna get a SS1LE either next year or early 2024 so until then I’m gonna be asking a lot of stupid questions. Anyways I’m wondering how many miles you can get out of the stock Goodyear f1 super car tires becuase I’ve heard they don’t last that long. Are there any good replacements for them that have similar performance that can be daily driven and last a longer time? Preferably I would like if the tires would last me over a year of driving ~12k miles.
04-15-2022, 03:06 AM | #2 |
Drives: 2017 2SS Arctic blue fully loaded Join Date: Mar 2021
mine have gone 7k miles and i'de say by 12k miles they will be shot
04-15-2022, 06:38 AM | #3 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I think 12K is about average and a reasonable expectation. Daily driver and street only you should be fine.
04-15-2022, 07:00 AM | #4 |
Around 12000 miles if you street drive with no track events. Keep the air pressure checked also. It seems though after 12000 miles they are almost drag radials on the rear.
04-15-2022, 07:12 AM | #5 |
Drives: 2021 LT1 6spd Join Date: Nov 2020
How are the F1 Supercar tires? They're one of the cheaper options in 285/30/20 right now. I understand they're not ideal in the rain?
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
04-15-2022, 07:24 AM | #6 |
Drives: 18 2SS 1LE, 20 Canyon Denali Join Date: Feb 2016
I’ll be using mine through another season which should put me at about 15k when they get changed. Depending on how hard you push them 12-15k miles is reasonable i think.
Mike
Current Garage: 18' 2SS 1LE, Hyper Blue 23' GMC Canyon Denali Previously: 20' GMC Canyon Denali 16' 2SS 6MT, Hyper Blue, Kalahari, 20" PVW Chrome Split wheels, NPP, MRC (Total Loss) 14' Ford Edge Sport 06' Saab 9-7x,13' Nissan 370z Sport, 12' VW Jetta GLI, 02' Olds Bravada |
04-15-2022, 08:04 AM | #7 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Unlike other tires like MT/R888R's which you basically do not drive in the rain. You also do not want to drive them in cold weather environment even cold dry pavement is dangerous if you even remotely look at the gas pedal. If you want an all year round tire, Probably look into the Continental WS6 extreme contacts. A lot of people rant and rave about those. But if you want summer performance then the F1's are solid, although there are better more expensive options that you either can or can't drive in rain and usually don't last much past 6000 miles with notable exception to Michelins I believe which have the same durability as the F1's and or same or better performance, but also a higher price tag. Another option to make those F1's last longer. Buy a new set of wheels, with some All Season tires, and swap them in the winter time like I do. So the only miles I put on the tires is in the summer. Which figure for me driving to work every day over 3 months is about 3600 miles. The tires should last almost 3 maybe 4 summer seasons depending on how aggressive you are at driving. To answer your other question: I use Yokohama Advan V105's on the front of my car, with the F1 SC3's on the back. The Advan V105's are not expensive I think I got mine for like $160/ea. And they have a great performance rating. The newer version I think is the V601? or V605 forget which number it is?
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | LS MSD Plug Wire Set | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq
04-15-2022, 08:19 AM | #8 | |
Drives: 2017 Camaro SS FIFTY Join Date: Dec 2016
04-15-2022, 08:49 AM | #9 | |
Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
Tire noise? Ride quality? Do they still hook up pretty well during when you put your foot in it?
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
04-15-2022, 09:16 AM | #10 |
Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
About 15-16k max, also depends how you drive.
04-15-2022, 10:38 AM | #11 |
Drives: 2016 2SS, Red Hot, NPP, Nav, M6 Join Date: Jul 2016
I got 18K out of mine & switched to BFG Comp 2+ when they went on sale at Costco. I like them but turn in is not as crisp as the original tires. But I needed a tire that also was AS as there is a lot of rain here.
04-15-2022, 11:51 AM | #12 |
Drives: 2SS 1LE Join Date: Oct 2011
Well, they better be WAY cheaper than PS4S, like less than half the price. I got about 10,000 out of them. They are also super-scary with just a little bit of water. They tram-line bad too. The PS4S is significantly (as in you notice it) better at all of these things and doesn't give up much in traction. The Supercars are good tires, but for a very small improvement in performance you make much bigger sacrifices in these areas compared to PS4S and other tires available. That might have something to do with the "sale price". I've seen the sale price pop up, but based on what people get out of PS4S, I calculated it still wasn't cost-effective for me.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
04-15-2022, 12:07 PM | #13 |
Drives: 2018 Camaro SS 1LE Join Date: Sep 2018
I got 11k as a DD. I bought another set of the OEM tire. I just liked how they handled and didn't want to waste money on something else. I only put about 4k miles per year on the car, so it wasn't a big deal.
04-15-2022, 12:34 PM | #14 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
11k miles for me before the rears were bald. I just replaced that set last month.
