04-12-2022, 07:09 PM | #1 |
Toyo R888R 14-day Test Period
I've purchased Toyo R888R rears, 325/30R19. I've got two weeks to decide whether to keep or return them. I'll do a 2-day T&T at the end of two weeks.
I would use them on open roads and at the strip, but they are primarily considered road course tires. Several modified Lambos weighing 3500# race them here. I did some nannies-off 60-130 today and didn't feel them spin [like 4S] or vibrate [like MT]. Very impressive, but I did hear a little bit of tread noise. Given the supply issues, I might order the 555RII now just in case I take the Toyos back. Anyone here have experience with them?
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
04-13-2022, 11:31 AM | #2 |
Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
I like them but I havent used the nittos before. They seem to hook great on my stock ZLE above 45 degrees and 35 mph. My only complaint is they howl like a 4X4 tire. As long as I do a good 5 sec. burnout at the dragstrip, they dead hook from a dig. Best 60' of 1.69.
04-13-2022, 09:20 PM | #3 | |
'20 ZL1 1LE A10.
04-13-2022, 09:57 PM | #4 | |
04-14-2022, 08:04 AM | #5 | |
Update Ordered the NT01 325/30ZR19 today and will drive the R888R until they arrive. The R888R's tread is designed for cornering/ racing I don't' do. UPDATE: I stayed with the R88Rs.
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. Last edited by JSH; 06-05-2022 at 08:33 AM. |
05-18-2022, 12:09 PM | #6 |
Drives: A10 ZL1 Join Date: Mar 2018
I had zero luck with Nitto’s. Yes my car is loud but I don’t get bothered by road noise with the Toyo’s
05-23-2022, 12:45 PM | #7 | |
I heard the Toyos work okay but wear really fast. They are the go to with ZL1 crowd. With the 17" setup on my A10 ZL1I ran a few 11.1s.
05-23-2022, 01:29 PM | #8 |
Drives: 2017 ZL1 Join Date: Jan 2017
I'm running Nitto 555RII (newer version of regular 555R). They hold the power well, they aren't loud, and you won't die if they get wet. I wouldn't believe they are a DR based on how streetable they are. I'm not a Nitto fan but I'd buy another set.
I'm currently using 55RII on the rear in 345/30R19 on 12" wide wheels along with 305/30R19 PS4S on the front.
05-23-2022, 09:31 PM | #9 | |
PKG4U
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S Mods after Warranty “Imma keep it stock” |
05-30-2022, 12:52 AM | #10 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
888R's are deafening
Lol Road noise is ridiculous BUT these tires are so damn sticky Keep you going straight too Just make sure you heat them up some first
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
06-04-2022, 11:34 PM | #11 |
Drives: None Join Date: Apr 2022
06-05-2022, 07:31 AM | #12 |
Thats at 8000 density altitude. Big difference in performance at different DA.
06-05-2022, 08:35 AM | #13 |
20% power loss up here
'20 ZL1 1LE A10.
06-05-2022, 03:09 PM | #14 |
No offense, but do you not know what 8043 DA means…?
