04-10-2022, 10:01 AM | #1 |
Drives: 2017 camaro 1ss 1le Join Date: Apr 2019
Rotors for 1le
New front rotors which one to get the stock ones or get the dba rings or girodisk rings? The price is about the same for all 3 right at $800. I like the weight savings on the girodisk, but have heard good things about the dba’s. Also the stock ones have done very well.
04-10-2022, 08:06 PM | #2 |
Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
its a wear item so id go cheap. and i thought OEM was only about $300 something a piece for a complete rotor and hat. GM makes a slotted rotor to save weight and help on track. its probably the most money but its complete.
this is a much better value when you get all the parts. https://www.gmpartsstore.com/oem-par...caAuzLEALw_wcB |
04-11-2022, 12:17 AM | #3 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
If you aren't tracking, no need to do anything but OEM.
https://www.rockauto.com/en/moreinfo...MZx64BBKOMszjb
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
04-11-2022, 12:37 AM | #4 |
It’s tracked majority of the time.
04-11-2022, 06:27 AM | #5 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
04-11-2022, 09:32 AM | #6 |
I’m thinking of going with the dba’s over the girodisk. I was thinking they would be a little better than the stock ones. Just wanted to get some feedback from people that have put them on in place of the stock ones.
04-11-2022, 10:47 AM | #7 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
I've run both the OEM and DBA rings pretty hard on track. I haven't found any subjective/objective difference between the two based on lap times, pedal feel, or longevity. I'd personally just go with whatever's cheapest, and if they're all the same price I'd go with OEM. Only reason I say OEM if cost is equal is that it's balanced as a unit and there's no possibility of user error when assembling the ring to the hat. Not that those are big risks if everything it being assembled properly, just a little extra peace of mind.
2017 SS 1LE.
04-11-2022, 01:53 PM | #8 | |
I use the dba's and like them a lot. I just put on my 2nd set of rings and made the jump to put them on the rear as well. knsbrakes.com usually has them in stock.
2017 HBM SS 1LE
04-11-2022, 10:00 PM | #9 |
Drives: Chevrolet CamaroSS 1LE Join Date: Mar 2022
In my experience with a C5 Corvette Z06 race car over many years of tracking, the the DBA,(Australian GM), rotors outlasted the GM dealer rotors. I'd call KNS Brakes. They sell both Girodisk and DBA if I'm not mistaken and really know what they're talking about. Based near VIR.
04-12-2022, 10:39 AM | #10 |
i just ordered some giro disc rings and hawk dtc60 pads
04-16-2022, 03:40 PM | #11 | |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
04-18-2022, 07:17 PM | #12 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
I believe you have to remove the hat it comes with and install the hat from your old rotor. There are some more detailed discussions about it if you search. I haven't done it myself. The slots will wear brake pads faster so I just went with another set of stock rotors. The stock rotors have directional cooling vanes inside (different part numbers for left and right) but the Corvette rotor linked from gmpartsstore above seems to be the same for both left and right.
04-20-2022, 11:58 PM | #13 |
04-21-2022, 02:04 PM | #14 |
Installing new girodisc hats/rotors, girodisc Ti shims and carbotech XP20 pads next weekend. First track day in 2 weeks, I'll post how it shakes out.
