04-07-2022, 05:16 AM | #1 |
Drives: 18 zl1 garnet red Join Date: Aug 2021
2021 1SS - pro charger or supercharger
What do you guys prefer? Super charger or pro charger? It’s a daily driver and currently has lt2 intake (would have to be replaced w SC) , rotofab cold air, headers and flex fuel tuned for e85. I like how it can be a daily drive and drive close to a stock car when I’m not getting on it.
I’ve popped the hood on a pro charged camaro and it would super loud so kind of leaning towards super charger but not 100% convinced. It’s duty is I do drive it daily and yes I do tend to mash the pedal daily as well and like how it currently drives. That’s partially why I’m leaning towards this instead of heads / cam route. Currently around 480hp, looking to get closer to 600hp |
04-07-2022, 06:11 AM | #2 | |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
04-07-2022, 06:26 AM | #3 | |
This. You’ll need more fuel if you want to go past 550-575 WHP. LT4 fueling is a relatively cheap and effective upgrade.
04-07-2022, 06:28 AM | #4 |
I prefer my Maggie PD supercharger because it behaves almost like a giant NA motor whose extra displacement is switched on and off with the throttle pedal (bypass), and once the car hooks, I have continuous traction and a flat-ish torque curve, with no crazy torque jumps in the middle of the rev range.
04-07-2022, 06:51 AM | #5 |
If my car needs better injectors , pumps then I’ll
Do it for sure. I’m leaning towards the Maggie if I were to head that route I like the idea of steady power instead of midrange surge |
04-07-2022, 02:50 PM | #6 | |
Note, be aware that stock LT1s have an extra sensitivity to supercharging, due to tight gaps on the rings. People have found as tight as .007" gap for the top ring in an LT1, that is very tight for a bore above 4" and having a blower added on. Just mentioning so that your eyes are open if you choose to do this mod to your car. Your noise concern about the Procharger which you saw could be addressed to some extent by ordering the optional quiet gear set (helical gears). Alternately, the ECS/Paxton 1500 supercharger is pretty quiet, could barely even tell that it was there quite honestly on mine, and that was with the stock exhaust system. With headers, I doubt that you could hear any sound from the 1500 over the exhaust noise. You DEFINITELY will need to upgrade the fuel system if you want to run an ethanol blend with your flex sensor after a blower install. Stock motor with base blower kit basically maxes out the LT1 fuel system on 93, or even exceeds it in many cases quite honestly, therefore adding more power above base (headers etc) or more ethanol content would only make it worse. |
04-07-2022, 03:29 PM | #7 | |
04-07-2022, 03:30 PM | #8 | |
04-07-2022, 03:56 PM | #9 |
The tight ring gaps are more problematic when trying to run a high compression engine with boost on 93 octane. If you run Ethanol fuel(E40+) that will pull a lot of heat out of the cylinder and help keep the rings from expanding to the point they butt. I have been running the SBE for 4yrs with boost and it's still going strong. I also have been running E since 2 months after I bought the car back in 2017.
If you spend a little time researching you will see that most SBE LT1 boost failures happen with pump gas. Very few failures on Ethanol. Pump piss gas isn't enough octane for a 11.5:1 engine designed to run NA with boost. Companies released kits claiming you can run 7-8psi around 550whp making it sound like a simple deal to attract buyers...pure marketing BS. I wouldn't waste time even boosting a SBE LT1 on pump gas. Upgrade the fuel system, run some E, or don't even mess with FI. If you are hellbent on pump gas then lower the compression with a GPI drop in rod/piston kit...jm2c
2016 NFG 1SS A8
04-07-2022, 04:53 PM | #10 |
I’ve got a flex fuel kit and pretty much fill up on E everytime. I’m doing my research too and that’s why I ask you guys who have been there done that too
04-07-2022, 05:00 PM | #11 | |
04-07-2022, 05:19 PM | #12 |
04-07-2022, 05:21 PM | #13 | |
04-08-2022, 05:17 AM | #14 | |
Since you like dyno sheets, below will be a screenshot of the ECS/Paxton 1500 base kit on a stock engine, stock exhaust, with no methanol injection, the dyno chart is from their website. |
