Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Engine Internals
Old 01-18-2022, 03:20 PM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
2016-2019 CAMARO 6 SS SOLER PERFORMANCE 87MM THROTTLE BODY
This Soler Performance Premium Throttle Body comes with easy to understand instructions for a 15 minute or less install!
FEATURES:
• Optimized Active Contours (Both Upstream & Downstream)
• Porting Taper and Upstream Bore (Lip & Bore Reduction)
• Greater Discharge Coefficient of Plate/Blade
• 16 Ra Microinch, Diamond Polished Surface Finish (Lower Skin Friction)
• Half-Shaft (Front & Back) for Larger WOT Flow Area (91 mm Effective Bore)
• Self-Cleaning Throat/Flow Gap
• Minimized Gear Backlash
• Countersunk, Thread-locked, and Peened Screws
• Higher Quality
• Made from Brand New OEM Parts
• Lower weight to power ratio at part throttle, for a more nimble/spirited driving experience (We doubled the rate of change of mass airflow (MAF) from 1.2 g/s-deg to 2.4 g/s-deg), 100% Increase!
• Linearization and smoothing of the curve for a more predictable response and crisper shifts
• Immediate response right off idling while keeping idling function undisturbed (No Hesitation/Stumble)
• Does not require tuning. Warranty safe.
• More air/power at every single throttle position after idle. Crucial for starting or expanding power gain modifications
• Easy Installation (15 Minutes or Less )
APPLICATION 2016, 2017, 2018, 2019 CAMARO 6 SS
southerncarparts is offline   Reply With Quote
Old 02-10-2023, 03:09 AM   #2
southerncarparts
Thank You for shopping at https://www.southerncarparts.com/201...ttle-body.html
