01-11-2022, 06:45 PM | #1 |
Drives: Camaro 2LT RS Join Date: Dec 2021
Replacing compressor kit with spare tire
My car came with a compressor kit in the trunk. I'd prefer a spare tire. Anyone out there replace their kit with a spare tire....and is the room provided work. In other words, are the kits and spare tires interchangeable?
01-11-2022, 06:49 PM | #2 |
Drives: ABM #93 Join Date: Oct 2018
The 20” wheel and tire will not fit. If you’ve got 18’s they will fit.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
01-11-2022, 07:38 PM | #3 |
Drives: 2010 2SS/RS, VR ext/Blk Int Join Date: Jul 2012
I just use a stock wheel. The spare kits can only be used on the front since they are smaller diameter tires.
01-11-2022, 09:34 PM | #4 |
Drives: 2014 1ss camaro Join Date: Jul 2017
yeah I put a full size 20 in mine eats up the trunk space. oh well. when I bought my American racing wheels. I took one of my stock front wheels and use it as a spare. it will fit the front and back.
01-11-2022, 11:48 PM | #5 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
The space will accommodate a 18" wheel and tire, but an 18" will not clear the brakes if you have the optional Brembo brake package. To clear those, requires the 20" wheels and tires , but the 20" wheels won't fit in the spare tire well. Thus instead of a 20" spare, they give you the inflator/fix-a-flat combo.
I belive some have found a source for a mini-spare that will fit, but I have no idea what it was they found. Perhaps a search might find an old thread about a mini-spare? |
01-12-2022, 04:31 AM | #6 |
Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
Here is a full kit. You would also need a 2" spacer to clear the front calipers. They also offer different package options.
https://modernspare.com/product/2010...ncluding-z-28/ |
01-12-2022, 04:35 AM | #7 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
I bought a spare wheel from a BMW X5 and put it directly in the trunk under the carpet.
Given how many times I will or likely will not need it, so instead of a full with full wheel trunk, I will swap the front wheel behind the rear wheel and put the spare wheel on the front axle. There is no need for spacers and it will fit through the Brembo brakes.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
01-12-2022, 04:53 AM | #8 |
Slick idea George!
01-12-2022, 05:09 AM | #9 |
01-12-2022, 08:52 AM | #10 | |
01-12-2022, 09:46 AM | #11 | |
376 cubic inches of fun
This is exactly the setup I had for a while (including shop rags) on long road trips. Frankly, I gave it up at my own peril after about 7 uneventful years. |
01-12-2022, 10:44 AM | #12 | |
This forum has given me a lot. The Camaro5 community accepted me, even though I from somewhere on the other side of the globe and I still don't speak English properly . So I try not only to obtain information, but also to return it, as much as possible
01-12-2022, 12:00 PM | #13 | |
01-12-2022, 12:04 PM | #14 |
The last thing I want is for that wheel to come crashing forward in a front end collision. The first law of motion in physics can be a killer.
