01-05-2022, 02:23 PM | #1 |
www.1baddogracing.com
Drives: 2010 IOM 2SS/RS Auto Join Date: Apr 2011
Forgestar F14 Recommended Tire Size
Hi -
I am looking to run the following wheels on my son's car and wanted recommendations on the biggest tire sizes for a stock suspension 2010 Camaro. Forgestar F14- 5x120 - 20x9 (offset 35) and 20x10.5 (offset 40) Thank you
2010 Camaro 2SS/RS Aqua Blue Metalllic (bolt-ons)
2020 Camaro 2SS/RS Satin Steel Metallic - Shock and Steel Edition 1 of 98 - A10 (bolt-ons) 2010 Camaro 2SS/RS IOM - 1,023 RWHP 813RWTQ (Previous Paxton Record Holder: 9.82@139) Built and Tuned by Heintz Racing Go: DSS 9", RPM Trans TH400, Carlyle Racing 15" Conversion, ECS Vortech YSI-B, Fore Fuel System, ID1700, Gall Racing 427 C.I LSX, Mast 285CC Heads, HR Custom Cam Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels http://www.HeintzRacing.com http://www.youtube.com/user/1baddogracing Last edited by Rockit_z28; 01-05-2022 at 03:32 PM. |
01-05-2022, 03:29 PM | #2 |
Drives: 2012 SS Join Date: Dec 2021
offset will determine the size that will fit.
2012 Camaro SS
01-05-2022, 03:32 PM | #3 |
Thank you. I added it above.
2020 Camaro 2SS/RS Satin Steel Metallic - Shock and Steel Edition 1 of 98 - A10 (bolt-ons) 2010 Camaro 2SS/RS IOM - 1,023 RWHP 813RWTQ (Previous Paxton Record Holder: 9.82@139) Built and Tuned by Heintz Racing Go: DSS 9", RPM Trans TH400, Carlyle Racing 15" Conversion, ECS Vortech YSI-B, Fore Fuel System, ID1700, Gall Racing 427 C.I LSX, Mast 285CC Heads, HR Custom Cam Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels http://www.HeintzRacing.com http://www.youtube.com/user/1baddogracing |
01-07-2022, 09:28 AM | #4 |
Well I'm assuming for "stock suspension" you are not lowered either? The 20x9 front I wouldn't go any wider than a 275/40 or 275/35, the 275/35 will give you a bit lower stance than the 40, on the rear you can run either a 305/35 or the wider 315/35 which is what I did on my 20x10.5's I used to have. I even ran the 315/35's on my 10.0 wides I had for 7 years with no issues.
01-07-2022, 11:53 AM | #5 |
again, depends on the offset. some people have clearance issues on the inside with 315's.
2012 Camaro SS
01-07-2022, 12:08 PM | #6 |
2012 Camaro SS
01-07-2022, 04:58 PM | #7 |
I have had +25,+30,+43 all on the rears with the 315's no problem on 10.0-10.5 wide wheels. Yes the offset will determine, plus the style of the wheel. If you purchase wheels made for the year Camaro you have, you won't have an issue as they are "fitted" for the car.
01-07-2022, 05:00 PM | #8 | |
