10-24-2021, 02:29 AM | #1 |
Drives: third gen Join Date: Sep 2013
Weird ac noise and problem
So recently ac went out I assume it's probably compressor so will replace that soon but I have noticed if I run the ac or even the heat my car will make this weird almost water drop sound and when car is at complete stop I can feel the brake pedal kinda of shake. I will try get video of noise but find it weird that it does this with both ac and heat.
10-24-2021, 06:56 AM | #2 |
Drives: 2012 Camaro SS Join Date: Dec 2019
If you’re at a stop and the brake pedal shakes and you hear a noise it’s the abs kicking on. Check for codes
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
10-24-2021, 09:19 AM | #3 |
Only code I get is the tire pressure sensor cause I got Aftermarket rims and have not put new sensors on yet would that cause abs issues?
10-25-2021, 07:50 AM | #4 |
The compressor may be putting to much drag on the motor causing the idle to drop to low to supply vacuum to the booster. You might want to unplug the compressor and see if that makes a difference.
09-19-2023, 11:43 PM | #5 |
Old thread still trying solve issue it seems to happen when the defrost is running or has ran so I'm thinking ac compressor or belt it sounds like a clown horn I took a video can kind of hear it
