Old 10-17-2021, 02:48 PM   #1
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
Drives: SIM 2SS/RS M6
Rear diff leaking
I have a 17’ 1LE 5k miles. Noticed the rear diff was glossy looking- had a coating of fluid. Upon further examination I saw the passenger side of the diff casing was also coated with fluid and there is a ring of fluid where the axle joins. Guessing maybe a bad seal. It should still be within the 5 year power train- not sure how involved of a repair this may be.
"Letty" Murdered out 2013 Camaro 1LE. (Old car SIM 2010 2SS/RS)
5th_GEN_SS is offline   Reply With Quote
Old 10-17-2021, 05:28 PM   #2
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
From the pics it does not look like a leak. Have the dealer workshop look at it just to be on the safe side.
Old 10-17-2021, 05:44 PM   #3
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
What would be causing the fluid to cover the exterior casing? It looks like it dripped down- maybe a slow leak?
Old 10-17-2021, 06:42 PM   #4
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Your half shafts bolts are backing out and the seal is not a perfect seal, thus the small leak. Your blue paint lines on your bolts prove that, they are off counter clock wise off center. They need to be torque down to specs and possible you have the wrong shorter bolts. There is a TSB on this.
Chevrolet TSB #16-NA-399
2017 Chevrolet Camaro
https://static.nhtsa.gov/odi/tsbs/20...11767-9999.pdf
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 10-17-2021, 07:10 PM   #5
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
Thanks for the info. I think I saw this before but for some reason I thought I had the longer bolts.
Old 10-17-2021, 07:21 PM   #6
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
I looked closer at the pic and there are two markings - the bolt marking does carry over to the retainer plate so it appears maybe they have not moved?
Old 10-17-2021, 07:32 PM   #7
Trochoidal
Drives: 2017 Camaro 2SS A8
I’m going to go with they performed the TSB and someone didn’t remove the original torque stripe. They need to mark it after the TSB to show they were installed for future reference if you came in for service. It depends on the service history And if it wasn’t in for the TSB who knows why the 2 sets of marks.
Are you the original owner?
Old 10-17-2021, 07:48 PM   #8
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
Yeah I am the original owner. I don’t think the bolts were ever changed afterwards. Maybe they corrected them from the factory- explaining two marks?
Old 10-17-2021, 08:04 PM   #9
Trochoidal
It seems possible. Like you said it’s odd the marks line up perfectly.
An older thread discussing these bolts. Nothing in here discussing torquing and backing them off.
Now I’m curious if the first mark was the 37.5 lbs and the 2nd was the additional 45°??
I check those bolts every time the car is on the lift and I don’t recall seeing two torque stripes.
https://www.camaro6.com/forums/showthread.php?t=505246
Old 10-17-2021, 08:13 PM   #10
BlackbeastSS2
okay if you say so, here is a pic of a correct blue paint torque mark.
Old 10-17-2021, 08:16 PM   #11
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
Right but look at mine- I have two marks
Old 10-21-2021, 11:09 PM   #12
tmalaquin
Drives: Blue ss 1le 18
I have the same sipping condition on my diff housing, torque paint looks ok. Curious to know what the dealer says, keep me posted !
tmalaquin is offline   Reply With Quote
Old 10-22-2021, 09:09 AM   #13
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Def need to investigate that TSP, your bolts have backed out. Does that have anything to do with a minor leak, I don't think so and actually in standard olden timey time rear diffs it was extremely common to have some oily staining or residue on the cover.
Old 10-22-2021, 04:02 PM   #14
Trochoidal
I’m with you on the two marks. I don’t see how a bolt backs out and ends up with a 2nd paint mark lining up perfectly with the backed out bolt.
Have you had the time to check the torque on those bolts?
