Old 08-08-2021, 12:07 PM   #1
parish8
Drives: 17 SS a8
2017 SS A8 1000+hp twin turbo
I am sure I am forgetting a lot of things. If your interested and need more pics of something let me know. the car isn't perfect, it has a couple of door dings. It drives amazing for what it is but it doesn't drive like a 100% stock camaro.
2017 Chevy Camaro SS A8 8200miles
$45k
Turbo set up
twin precision 67mm turbos with stainless vband in/out exhaust housings
precision wg's
precision bov
turbowerx exa return pump
turbo guard(air filters do fit)
turbo blankets
3" x pipe to 3" magnaflow mufflers
vband swapable dumps
fi interchillers stage 2 interchiller(ac still works)
massive g1pro air to water intercooler intake
rear mounted intercooler tank with variable speed pumps to the interchiller and intercooler
1 gallon air compressor for dome boost control
Engine
gen v 5.3
gpi drop in rods and pistons
arp head studs
texas speed turbo cam with larger fuel pump lobe
btr rpm springs
3/8" pushrods
johnson link bar axle oiling lifters
btr trunion kit
stock mls head gasket
mighty mouse breather
fuel system
lt4 in tank pump
lt4 hpfp
lt4 hp fuel injectors
custom surge tank with 4 deatschwerks il350 pumps staged(2000hp capable)
~1100cc deatschwerks port injectors(1500hp capable when combined with the direct injectors)
Trans
Steven Rankins built A8
billet input shaft
circle d triple disk converter
Driveline
dss driveshaft
gforce outlaw axles
bmr double adjustable everything in the back
bmr cradle lock out
bmr diff bushings
carlile 15" brake kit in the rear
aerospace street brake kit in the front
viking double adjustable rear shocks
wheels and tires
15x10 forge star drag wheel in bronze burst
new 325/50/15 et street r rear tires
skinny front forge star bronze burst wheels
bias ply skinny tires front tires
also have a set of normal sized forge star bronze burst front rims and tires
also have the stock front rims and tires and the stock rear rims
computer
hp tuners tuned stock ecm running direct injection, throttle and trans...
ms3 pro ultimate running port injection, ignition, boost control, pumps, 2 step...
microsoft surface tablet mounted for gauges and quick adjustments.
the ms3 pro allows for a very long list of logged data. ambient air temp, turbo inlet air temp, post turbo air temp, post intercooler air temp
pre and post intercooler pressure, pre turbine exhaust pressure, intercooler tank temp, intercooler inlet fluid temp, intercooler outlet fluid temp, coolant system pressure
the tablet allows for real time and 30 second look backs of boost, afr, fuel pressure, traction. it is user designable.
the ms3 pro has speed based boost OR 2 map rpm based with multiple scrambles
current set up uses the left paddle for line lock + 3 step, right paddle for 2step, boost is rpm based for the initial gear and after the shift boost is again rpm based but a separate table, any time above 5000rpm the left and right paddles act of boost scram 1 and boost scram 2. The trans takes care of itself, you never have to take your hands off the wheel.
Old 08-08-2021, 05:17 PM   #2
parish8
Drives: 17 SS a8
Here is a walk around video from today.
https://youtu.be/cEvabo4jdPY
