Vararam
Old 05-31-2021, 05:19 PM   #1
Tomd27858
Drives: 2011 Camaro SS
2011 SS RS Headlight Fix
I have a 2011 SS RS that has a headlight that is giving me some problems. The headlight is aimed too high. I tried to adjust it and it appears that the adjustment screw isn't working. The light also jiggles a bit when you hit bumps in the road. You can see a little movement at night.
Has anyone tried a repair to these lights or is a replacement in order?
It appears that there are not many replacement options for camaros that came with the RS lighting package. Most reasonably priced options are for non-RS camaros.
I appreciate any insight you have to offer.
Thanks!
Tomd27858 is offline   Reply With Quote
Old 05-31-2021, 05:37 PM   #2
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
It's quite possible the adjustment screw was backed off too much, and it's no longer catching on the mechanism. You'll probably need to pull the headlight out. Good news is it should be a $0 fix.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 06-01-2021, 07:39 AM   #3
Tomd27858
Thanks. I wrestled a bit with it last night and attempted to get the adjustment working. I opened up the back of the light (where you replace the light bulb) and pulled on the projector and got it a bit lower while working the adjustment screws. Things are still a bit loose in there. The light bounces a bit when driving.
Is there a trick to getting things tightened up? I can't feel where the connections are. It sure is tight in there.
Thanks again.
Old 06-03-2021, 08:40 AM   #4
ccss713
Drives: 2010 2SS
TYC does make replacements, FYI. I have them in my 2010. The quality is definitely not OEM if you are anal about that but the light output is very good. I had to replace mine because they were absurdly dim. Apparently the reflector coating inside the headlight flakes off over time and it seems to be a common problem with these lights.
Part numbers:
20924600SET
20924500
20924600
ccss713 is offline   Reply With Quote
Old 06-06-2021, 04:19 PM   #5
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
Is the high-beam door inside the headlight assembly stuck? I use my high-beams very rarely and sometimes the door inside my passenger side headlight gets stuck. This makes the headlight look out of alignment.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 06-07-2021, 01:00 PM   #6
Tomd27858
Ok. This may be a crazy ask. How do you find the high beam door?
Old 06-07-2021, 02:07 PM   #7
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
With the car off you should be able to hear them. If you get up by the affected headlight and have someone push forward on the high beam/signal lever and then let go, you should hear the shutter open and close. They are fairly loud with the engine off.
InFiD3ViL is online now   Reply With Quote
