Vararam
Old 05-21-2021, 03:00 AM   #1
CAMVROOM
Drives: CAMARO 2014
Part called that attach front bumper to line fender
For camaro 2014. I was wondering if someone know what the part (looks like a bracket) that attach the side of the front bumper to wheel liner fender. There is something that looks like it calledZL1 Front Bumper extension but I do not want the "extension look". Mine was ripped off the left side of front bumper.
I know that this part looks like it usually comes with the bumper normally so I am not sure if they sell it separately since it is normally glued to the front bumper? I am hoping that I can get the part only and glue it back on to my bumper if not i have to by a used 1 and ripped that off from it.
If you able to state the part #, that is a plus
thanks in advance, j.
CAMVROOM is offline   Reply With Quote
Old 05-21-2021, 04:22 AM   #2
1COR.1:18
Whosoever Will
1COR.1:18's Avatar
Drives: 2010 1LT Victory Red
https://www.gmpartsdirect.com/v-2014...mponents-front
1COR.1:18 is online now   Reply With Quote
Old 05-21-2021, 03:35 PM   #3
CAMVROOM
Drives: CAMARO 2014
none of the parts on the hyperlink (https://www.gmpartsdirect.com/v-2014...mponents-front) match the part i need. that's why I wasnt sure if they sell it separately.
Old 05-21-2021, 04:09 PM   #4
1COR.1:18
Whosoever Will
1COR.1:18's Avatar
Did you try this one??? https://www.gmpartsdirect.com/v-2014...and-components
Old 05-21-2021, 11:19 PM   #5
CAMVROOM
Drives: CAMARO 2014
I didnt before but now I did. Base on the new hyperlink, the part looks like the drawing of part #7 but I know its not the insulator. It attaches in the front of wheel liner fender to the front bumper. Thank you for trying to help me.
Old 05-22-2021, 06:01 AM   #6
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
I know exactly the part you’re talking about. They break often. Might* be part number 11, but it’s hard to say
joshnmn is offline   Reply With Quote
Old 05-23-2021, 10:44 PM   #7
Cyber10
Cyber10's Avatar
Drives: 2010 Camaro 2SS/RS
Been awhile since I've had my front bumper off but on most vehicles now the fender liner attaches to the bumper itself, there are plastic tabs molded into the inside of the bumper that the mounting screws go through.
491 hp/438 tq
LS3 Conversion | Comp Cam Custom Grind | Mast Heads | Comp Cam Push Rods | LS7 Timing Chain | 180 Thermostat | Ported Intake | Ported TB | SLP UDP | K & N CAI | Custom 3800 Stall Converter | Aluminum 1 Piece Driveshaft | Kooks 1 7/8" LTH | High Flow Cats | ARH 3" Exhaust | ARH Mufflers | Eibach Lowering Springs | BMR Floor Brace Subframe Connectors with Tunnel Brace | BMR Moly Lower Rear Control Arms | Oracle LED Halo Kit
Cyber10 is offline   Reply With Quote
Old 05-23-2021, 11:21 PM   #8
L6611983
what is the part number for number 4?
L6611983 is offline   Reply With Quote
Old 05-25-2021, 01:03 AM   #9
CAMVROOM
Drives: CAMARO 2014
#4 actually attach the side left fender (not the wheel liner fender) to the front bumper.
cyber10, I did do more research and see what you mean about it being molded. My old bumper was wrecked so I got a new one. I was not able to see the wreck bumper for the "molded". My new bumper has it as a an "attached" bracket so its like glued on (no screws) for some reason and not molded.
O well most likely I can get the zl1 extension and make the bracket myself
Thanks to every1 that helped me.
Old 12-20-2022, 11:58 AM   #10
15sscamaro
Drives: 2015 camaro ss
Hey man, did it work for you? Could you post us pics, im running in the same issue here!
15sscamaro is offline   Reply With Quote
