05-13-2021, 12:17 PM | #1 |
Procharger Air Inlet Install Issue
I installed a Procharger P1X kit this week (2017 SS/LT1), but I'm having extreme difficulty with getting the hard plastic S-shaped supercharger air intake to fit over the inlet to the supercharger. I contacted Procharger, and they assured me it was supposed to fit. They recommended applying some heat before attempting to install. I fought with it for quite a while with it with no luck. I did apply "some" heat with a hair dryer, but still wasn't happening for me.
I measured the OD of the supercharger inlet and the ID of the plastic inlet tube. There is almost .100" difference between the two. (Supercharger inlet OD was .100" bigger than ID of tube). My question is what has been the experience of others with this tube? I can get it hotter with a heat gun of course, but I'm concerned whether or not heating and forcing the tube is going to crack the tube with that much of an interference fit. |
05-13-2021, 09:13 PM | #2 |
Drives: 2018 1SS 1LE Join Date: Jul 2012
Mine was difficult to get on too. I just kept working at it and it eventually went on. It was a tight fit for sure.
2018 SS 1LE—707rwhp, 615rwtq
2009 Pontiac G8 GT—605rwhp, SOLD |
05-15-2021, 02:30 PM | #3 |
Update... Took quite a bit of heat from my heat gun, but once I got it hot enough it slid on fairly easily actually.
Theres no way it would have gone on w/o the heat for sure. |
05-18-2021, 09:00 AM | #4 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
that's weird, i have a F1A setup but my inlet was super easy to install. glad you were able to find out the issue.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
05-19-2021, 06:05 PM | #5 |
Drives: 2016 2SS Mosaic Black 6M, 1969 Z28 Join Date: Apr 2019
I cut a small chamfer on the inside of the plastic tube so it started easier... Made a difference, only about 1/16" chamfer.
06-12-2021, 07:50 PM | #6 |
Drives: 2017 50th Camaro SS Join Date: Jul 2016
Had to heat mine to go on the P1X
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
