05-09-2021, 09:53 PM | #1 |
Drives: 2011 Camaro 2SS/RS Join Date: Jan 2011
How clean for new gasket?
I’m replacing the water pump and other parts. This is how clean I’ve gotten the surface so far. How clean does it need to be before applying a new gasket? Does all of that black residual need to come off?
If it does, any tips or tricks? Thanks
Allen
2011 Camaro 2SS/RS |
05-09-2021, 09:58 PM | #2 |
Drives: 15 Camaro SS Join Date: Oct 2018
I cleaned mine pretty well. Not sure its 100% needed, but i did it. I used a razor blade and a rag with solvent. Go slow and be careful. Most of it will come off.
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
05-10-2021, 05:53 AM | #3 |
I use a razor blade as well. very lightly, just enough to get the residue off and make sure it doesn't dig into the block/mounting surface. As gunchamp said, slow and careful.
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
05-10-2021, 06:59 AM | #4 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
You need a flat surface to seal against. I would clean it up a bit more with a razor as mentioned. Don't want to have to take it apart again because of a leak.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
05-10-2021, 07:43 AM | #5 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Plastic razor made specificially for this purpose. Get it clean and not damage the surface. All auto parts stores have them for a couple bucks.
05-10-2021, 02:02 PM | #6 |
Thank you everyone for your input. I have plastic blades I can use. Not sure why I didn’t think of using them sooner.
Thanks!
Allen
