Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 04-26-2021, 09:47 AM   #1
Cheap Guy
Cheap Guy's Avatar
Drives: 2011 Camaro SS
The time has finally come for new amp
After a couple of years playing around with my sound system, it's time to replace the BA amp. I have aftermarket Rockford Fosgate speakers and Pioneer head unit and I plan on going the K.I.S.S. route and use the S-name harness despite it being a bit pricey. What's the new consensus replacement amp that fits in the stock mounting area since I don't want a surfboard back there? Four or five channels is fine since I may replace the powered RF sub with a dedicated sub box sometimes in the future. Several of the JL amps listed in old threads are now discontinued. My preference is to go with a RF amp since I already have their speakers in the front but what ever is the most cost effective solution, so long as it's not some off-brand amp, is fine with me.
My Little Mid-Life Crisis Cure!
First - 1997 Camaro 3800 Y87, M5, Green - Gone | Second - 1997 LT1 Z28, M6, Silver - Sold | Third - 1999 LS1 Z28, M6, Pewter, Almost Stock! - Sold
Current - 2011 Camaro SS, M6, black, 1LE suspension parts - Current
Cheap Guy is offline   Reply With Quote
Old 04-28-2021, 04:47 PM   #2
c5dreamer
Drives: Tacoma/2LTRS
Look at the kicker key loc amps, it has a feature that fixes bass roll off
c5dreamer is offline   Reply With Quote
Old 05-06-2021, 10:52 AM   #3
Dega Man
Drives: ZL1
I think you will be very happy with the Alpine PDX V9 amp and it will fit on a mounting board directly where the factory amp is mounted. I got the FARK harness and mounting board from ********.
Dega Man is offline   Reply With Quote
Old 05-06-2021, 07:16 PM   #4
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
I may have a Alpine PDR-V75, mounting board and S u b t h u m p harness for sale here soon. All in excellent shape, hardly used. PM me if you are interested.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 05-07-2021, 07:45 AM   #5
Cheap Guy
Cheap Guy's Avatar
Dang, I just bought both the harness and an amp a few days ago. Oh well, at least they shipped quick.
Old 05-07-2021, 10:24 PM   #6
Cheap Guy
Cheap Guy's Avatar
Pretty much done.
Ended up going with the Rockford Fosgate Prime R2-500x4 especially when a local store had it priced at $200, versus $279 everywhere else. I figured it might go better with the RF components up front and the RF powered subwoofer in the trunk. For ease of install, I used the ST mounting board and harness. While I was installing this, I also went back and redid the wiring for my RF powered subwoofer since I cheaped out with a Walmart wiring kit which has CCA wire which is universally panned as not the proper way to go. I did run separate power to both the amp and sub instead of using a power block which is probably the better way of doing it.
I still need to clean up the final wire routing to the amp but it’s pretty much done and wasn’t hard at all if you’re remotely familiar with car electronics. Now comes the hard part - tuning it - so I’ll be doing a lot of YT watching and reading whatever I can about tuning an amp. Even with everything set to zero, the RF components I put up front sound WAY better, to the extent that the rears really sound mediocre, but I’m done with the electronics this year, maybe I’ll replace them next year or late this fall. For now, I’ll just turned them down.
Now the better way to have done this would have to get a five channel amp and the sub box that’s a custom fit for the Camaro. I may actually do that down the line.
Old 05-07-2021, 10:56 PM   #7
AG454
AG454's Avatar
Good job. Did you get the S u b t h u m p rear speaker pigtails? Otherwise the rears won’t sound too good with a 4 channel amp. Actually, they still were lacking in sound quality with them I thought. I was just in my car today putting the stock amp back in. I could never get it to sound the way I wanted it to. I just put in a new headunit and it sounded even worse. Went back to stock amp with much better results.
Old 05-08-2021, 12:15 AM   #8
Cheap Guy
Cheap Guy's Avatar
Thanks!
I’m debating on the pigtails. I really mainly like a front sound stage and have the rears turned down anyway so it’s not a big deal but I really want it done as right as I can cost effectively do. That means I’m looking at rear speakers. It’s not that big a deal for me to spend a day doing it - it’s just that it’s going to be a never ending cycle - next I’ll want an integrated sub box, which will require another or a five channel amp, then better front speakers, etc. I’ve already changed the headunit three times just to upgrade to better technology (CarPlay then wireless CarPlay).
Edit: I put the pigtails on the rear speaker this morning. While it definitely makes a difference, they still sound weak (as expected) compared to the fronts. Smh, now I'm checking Crutchfield for bargains!
Old 05-11-2021, 02:32 PM   #9
AG454
AG454's Avatar
I felt the same way about the rears. I am not overly excited about taking the rear speakers out and replacing them. I think I may replace the fronts and like you go to a front dominant soundstage and call it quits.
Old 05-12-2021, 03:22 PM   #10
Cheap Guy
Cheap Guy's Avatar
I just finished buttoning everything up - I'm going to pay $30 for someone professional to tune all the gains and other stuff - and it sounds a lot better than it did before. Having said all that, it still doesn't sound as good as the system in a ten year old Chrysler to be honest. I think GM wasn't all that concerned about the system in the Camaro, figuring they'd throw whatever in there to keep the price down. The main issue is the system has almost no bass in stock set up, and I'm not even a big bass person. When you make all the adjustments to improve the bass, the clarity goes to crap. So now I'm into a new head unit (and associated hardware), new front speakers, and now a new amp - all quality stuff and it does sound a lot better but dang, it took all this to just get decent sound out of this car, and I'm not even an audiophile or whatever they call sound fanatics. I'm very tempted to keep chasing a better sound but right now, if I want to sell my car, it would take about an hour to put it back to stock. If I did new speakers in the rear, no way would I even think about doing it twice.
So I'm done - I think everything in this set up is all follows:
Pioneer Radio -DMH-W4660NEX - $500.00 (open box)
PAC Kit - RPK5-GM4101 - $300.00
Rockford Fosgate R1675-S (Front Speakers) - $80.00
Rockford Fosgate R2-500x4 (amp) - $200.00
Rockford Fosgate P300-8P (powered subwoofer) - $220.00
S-People stuff (harness, mounting bracket) - $155.00
Misc. stuff (amp kit, etc.) - $100.00
Approx. Total: $1550.00
You can probably do better on some items (I splurged on the head unit because I love wireless CarPlay) and I got discounts on some of the others (amp is regular price of $279.00) but you get idea of what it will end up costing you to chase just decent sound over the stock BA setup. From what I've read, $1600 isn't that bad for a decent upgrade. The good thing is you can easily do this yourself if you have just minimal skills and there's no real hacking up your car to do this.
Old 08-20-2022, 10:21 AM   #11
Cheap Guy
Cheap Guy's Avatar
Speaker Update...Alpine
After suffering a couple of years with the Rockford Fosgate R1675-S front speakers, I swapped over to Alpine S-S65C and like them much better. The RF had absolutely no mid bass, despite constantly playing with the EQ to try to tune them for more bass output. The twitters were also very harsh and overwhelming for my tastes. The Alpine just seemed to be a bit higher quality too. It's great how once you do something on a car, the second time around is much easier - did it in about an hour and half, taking my time.
Old 08-20-2022, 10:27 AM   #12
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
aftermarket pioneer deck will not have roll off
lemontwist is offline   Reply With Quote
