Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 4th Generation Camaros
Old 08-09-2008, 09:17 PM   #1
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
Angel Eye Mod (93-97 Camaros)
What you'll need:
-2 sets of angel eye driving lights http://www.brandsport.com/pilt-nv538w.html
-screwdriver, star key tool (for removing the old lights), needle nose pliers, power drill (to drill mounting holes), wire stripper (I used my pocket knife), electrical tape or shrink wrap, super glue
1. Removing the old lights
-Disconnect the negative battery terminal on your battery so you don't mess anything up on accident.
-Take out old headlights and brights. To do this, remove the spring on the bottom and unscrew the top adjusting screw. The old headlight fixtures will come out in one piece if you do it this way.
Spring location
-CUT the wires to the lights with wire cutters, as the harnesses will not be used.
Mounting the brackets
-Once all the old lights have been removed, it's time to mount the brackets for the new lights
-Line up the bracket, and the screw in the proper hole (inside lights = front hole, outside lights = middle hole)
-On the inner lights, use the farthest forward mounting hole on the bracket and mount the screw in as far back as you can and still be structurally sound. (I had to remove the plastic plug that the stock headlight adjustment screw mounted to in order to make enough room for the headlight itself) On the outer lights, use the middle hole to mount the bracket with still going back a good bit.
-Screw in each screw with the bracket in place. We are only using one screw for each bracket for adjustment purposes. If you want, you can use the sticky pads IN ADDITION to the screws, but the pads themselves are not enough to hold the lights in position. Also, if you use the sticky pads, you will not be able to adjust the bracket side-to-side later when you set the placement of the lights. You will superglue them later.
3. Mounting the lights.
-Mount the lights as low as possible in the brackets. This is pretty self explanatory.
4. Wiring
-Splice the wires into the new headlight wires
-Ops check/fitment check
-halo wiring v1
Since im running without regular fog lights, I spliced into the factory foglight harness. Being that there are 2 halos per side and only 1 foglight wire, you need to splice them 2-into-1
-halo wiring v2
You can run the halo’s off of the cigarette lighter if you so choose like in the pic below:
Also…. after doing some searching I found that Shbox.com has a writeup for accessory wiring for those who want to wire their halos inside the car which would allow you to run a manual switch in place of the ashtray or wherever else you decide to place it. This would require the use of the switch that came with the lights.
http://shbox.com/accy/Accessory.html - link to shbox’s wiring
switch that came with wiring:
5. Light adjustment
-The reason we only put one screw per bracket is to adjust the lights. So wait till night to do this step.
-The lights are very bright, so adjust the headlights so they point straight forward, but down about 20-30 degrees. This is so that you won’t blind any other traffic with your normal headlights, making it so that you won’t get pulled over.
-Adjust the brights so that they point straight forward and have no angle to them.
-Once the headlights are adjusted to your liking, put some super glue around the base of the brackets and between the light fixture and the brackets. This will make it so that they can't be bumped out of place.
Now you should be done. I will be adding more to this as I am working on a surround that goes around the lights and blocks behind it so you don’t see a mess of wires or anything… just the lights.
And heres some other pics for reference and final product:
old
new
Also, some of you were wondering about the wiring harness that comes with the lights, so I included some pics for that as well:
wiring harness
1 light
2light
relay
switch
fuse
diagram
I piss excellence
and fart awesomeness
Old 08-10-2008, 01:25 AM   #2
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
WANT NIGHT PIX!!!!
TAG UR IT is offline   Reply With Quote
Old 08-10-2008, 02:44 AM   #3
The_Beast_
THE GoldMember
The_Beast_'s Avatar
Drives: '92 Pathfinder A.K.A The BEAST
I want to see them at night.
So the Goldmember has spoken, So shall it be done.
_________________________________________________
AUGUST 2009 AURORA HITSS THE SSTREETSS!!!!!
~MY SSCHEME: BLACK W/GOLD BUMPER 2 BUMPER Z-28 SSTRIPESS.~
^In the wise words of Pink, "NO NOT MUSTANG GOLD"
Forget a automatic, a MUSCLE car needs STICK! To bad I'm getting auto
Originally Posted by The Lonely Island
IM RIDIN ON A DOLPHIN DOIN FLIPS N' SHIT!!!!
May The Beast Rest In Peace. For Now.
The_Beast_ is offline   Reply With Quote
Old 08-10-2008, 03:06 AM   #4
CamaroSpike23
Truth Enforcer
got some night pics of a friends car for now
and another friends car with his
and others of mine.
I piss excellence
Old 08-13-2008, 03:29 PM   #5
Shadow-phoenix
Terrorizing the streets
Shadow-phoenix's Avatar
Drives: 06 GTO, 92 Camaro RS, 84 Trans Am
Send a message via AIM to Shadow-phoenix Send a message via MSN to Shadow-phoenix Send a message via Yahoo to Shadow-phoenix
^ Those are some kick ass pics. I want your car... how much?
-Creating a monster-
Rust is the vehicular form of cancer.
A stupid owner is a Camaro's worst fear, second only to the though of going to the crusher.
Camaro: a vicious animal that eats rice for breakfast, and mustangs for dinner.
Shadow-phoenix is offline   Reply With Quote
Old 08-13-2008, 05:40 PM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Those don't look bad at all. I remember I was considering a PIAA set-up for my '95 but ended up loosing interest.
Good job though
'20 ZL1 Black "Fury"
Old 08-13-2008, 06:00 PM   #7
The_Blur
Moderator
The_Blur's Avatar
Drives: 2018 Harley-Davidson Street Bob
Send a message via AIM to The_Blur
I love these instructional threads. This was a great piece of work!
RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
Operation Demon//Buy at Invoice//RACECARWEAR
RESPECT ALL CARS. LOVE YOUR OWN.
warn 145:159 ban
The_Blur is offline   Reply With Quote
Old 08-14-2008, 03:53 PM   #8
CamaroSpike23
Truth Enforcer
thanks...sorry, not 4 sale.
Good job though
PIAA=$600.00
Angel Eye= $165.00
lol
ive got a bunch of them. ive been talking to a mod or 2 about setting up a whole section devoted to how-tos and instructional threads. its what im good at.
I piss excellence
Old 08-14-2008, 04:13 PM   #9
BowtieGuy
Enlightened
BowtieGuy's Avatar
Drives: Nothing Currently
I love those! Though they do look like they could be illegal in some areas.
If you believe it is your right to speak freely no matter the content, relevance, or intelligence of statement, then it is my duty to the powers that be to set you straight.
People have to talk about something just to keep their voice boxes in working order. So they'll have good voice boxes in case there's ever anything really meaningful to say.
Kurt Vonnegut
BowtieGuy is offline   Reply With Quote
Old 08-14-2008, 04:53 PM   #10
The_Beast_
THE GoldMember
The_Beast_'s Avatar
BTW: if I were you Id put a clear casing around the front so they dont get dirty. I would go crazy if my lights were exposed like that.
Old 08-14-2008, 05:18 PM   #11
CamaroSpike23
Truth Enforcer
the stock headlights are exposed like that. its not just a bulb sticking out there, the lights are in a housing.
I piss excellence
Old 08-15-2008, 02:41 AM   #12
TAG UR IT
TAG UR IT's Avatar
it is explicitly written in my will that my car will be destroyed upon my death (supposing i dont destroy the car during my death)
Old 08-23-2008, 08:33 PM   #13
CamaroSpike23
Truth Enforcer
NIGHT PICS
sorry for the shaky hands
I piss excellence
Old 08-24-2008, 02:47 PM   #14
CamaroSpike23
Truth Enforcer
ur welcome. lol
im going to shoot some more pics during different hours of the day with the lights on to show them better and with my headlight covers as well
I piss excellence
Door handles mod discussion Xanthos Cosmetics and Lighting Modification Discussions 19 07-24-2009 09:24 PM
Camaro's lineup? .Hack 5th Gen Camaro SS LS LT General Discussions 66 10-13-2008 07:06 AM
80,000-100,000 Camaros per year Txturbo Camaro Price | Ordering | Tracking | Dealers Discussions 28 08-16-2008 11:44 PM
LA Times: Design Changes Delay Camaro's Return to the Muscle-Car Race JustinZS 5th Gen Camaro SS LS LT General Discussions 36 04-01-2008 05:15 PM
