03-13-2021, 06:59 PM | #1 |
Drives: 2010 2LT/RS Join Date: Sep 2017
Lug nuts fit SAE sockets only, not metric
Hi all,
I was just wondering if anyone else has ever found their OEM lug nuts had issues with fitting a 22mm socket? I've always used a 7/8 until recently when I was gifted a 22mm socket and to my surprise, I found that it wouldn't fully seat onto my lugs. It would go in a bit then stop. However, my 7/8s fit perfectly fine with the tiniest wiggle space. I've been told that the lugs have been metric since the early 2000s but this situation has definitely confounded me. Cheers! |
03-13-2021, 07:01 PM | #2 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
I had to buy a thinner wall socket to fit my wheels but I'm pretty sure it's metric.
Sent from my Pixel 5 using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
03-14-2021, 06:03 AM | #3 |
Drives: Two 1984 Z28 / 2014 2SS/RS AGM L99 Join Date: Feb 2021
I used a 7/8 as well and I just pulled and polished all of mine .
03-14-2021, 07:44 AM | #4 |
It don’t come easy.
The difference between 7/8” and 22mm is approximately .010”. My guess is the reason you can’t fit the 22mm socket on the lug is from slight distortion from prior use of a SAE socket. I wouldn’t have any concern using a 7/8” socket.
03-14-2021, 09:57 AM | #5 |
This is exactly why I can fit a 22mm on some of mine without an issue, but the others give me a hard time.
03-14-2021, 05:27 PM | #6 |
wierd...i use a 4 way lug wrench on mine no problem
03-14-2021, 06:45 PM | #7 |
Same here and isn’t it 13/16” might be wrong.
Life is short, drive it like you stole it! |
03-14-2021, 11:55 PM | #8 |
Yeah that might be it. The ridges of the lug are a bit flatter per say vs the ones that fit the 22mm. The flat sides fit the 22mm socket fine but its the ridges that have issues fitting. I wonder if the ones that DO fit my 22mm will deform more over time to the point where it won't fit anymore...
03-15-2021, 08:52 AM | #9 |
Drives: too many to say! Join Date: Nov 2010
The nuts with the stainless cover can get damaged and cause tight fitment. Use of an impact gun is a leading cause of the damage
03-15-2021, 09:17 AM | #10 |
Started#gottalovethatblue
Softly off topic, but it was the first thing I thought of...
