Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Forced Induction - V6
Old 02-26-2021, 04:37 PM   #1
jimmyp
Drives: 2013 Camaro Convertible
Overkill S/C Pulleys
Anyone know if the quick change pulleys that overkill uses, are available anywhere else?
jimmyp is offline   Reply With Quote
Old 02-28-2021, 09:32 AM   #2
Pearlj10
Drives: 2011 Camaro 2LT
Shouldn’t any of these 8-rib pulleys offered directly from Vortech work?
https://vortechsuperchargers.com/pro...ant=7811181441
Pearlj10 is offline   Reply With Quote
Old 02-28-2021, 07:26 PM   #3
jimmyp
They should, but I'm not sure if it would line up with the crank pulley. It would be a lot easier to find one of the quick change ones. That might be the way I have to go though.
Old 02-28-2021, 07:43 PM   #4
Pearlj10
Good point on the alignment, I’d be curious to see what works.
Old 03-19-2021, 11:46 PM   #5
Pearlj10
Did you have any luck figuring this out? Thanks
Old 03-23-2021, 06:39 AM   #6
jimmyp
I haven't tried yet, I'm working on some other projects now, I was hoping someone knew where to get the overkill pulleys, because that would be a lot easier. This will probably be put off until later this year, when I have more time.
Old 03-23-2021, 10:06 AM   #7
Pearlj10
I actually pulled mine of Sunday and it’s just a regular Vortech brand 8 rib pulley. I’m upsizing (!) from a 3.6” to 3.7” pulley, trying to drop boost about 1 psi, to alleviate my HPFP issues where it can’t supply desired rail pressure at max boost/rpm. I’m hoping that a bit less boost will allow me to redline the motor safely and keep in the power band longer. I’ll report back on how it goes.
Old 03-26-2021, 06:26 AM   #8
bill522
Drives: 2014 LS Camaro
If you need better fueling on the high end :
LF4 ATSV Hitachi Fuel Pump
Tapout Tuning (AutoTech High Volume HPFP Internals Kit)
bill522 is offline   Reply With Quote
Old 03-28-2021, 03:00 PM   #9
Pearlj10
Bill522: thanks for the reply. Can you confirm that the LF4 pump internals work on the LLT HPFP?
Old 03-28-2021, 05:00 PM   #10
bill522
I don't know if it will work for LLT.( I always forget that motor) .Suggest contacting Will at Overkill. I know the LLT is a totally different beast than the LFX, and I would hate to give someone bad advice..
Old 04-06-2021, 08:51 AM   #11
LuckySave
Drives: Gen5LFXfi
does anyone know a part number for the belt tensioner? or a reference or any sort. Thank you kindly
LuckySave is offline   Reply With Quote
Old 04-06-2021, 10:02 AM   #12
Pearlj10
This tensioner by Gates is the one you want. Much stronger tensioner than the Dayco one that comes with kit: GAT 38485.
