02-17-2021, 09:47 AM | #1 |
Separate clutch reservoir bracket
For gto or 4oz wilwood clutch reservoir. Uses both factory brake master cylinder bolts. For more info and pics, search the forum for the thread on this topic. Gto reservoir can be used with factory soft fluid line with this bracket and wilwood reservoir needs a number of fittings to work with factory line or 1 fitting for the braided line.
Bracket=$20 shipped to lower 48 (PayPal F&F) PM if interested |
02-18-2021, 06:14 AM | #2 |
I wasn’t clear in my previous post. I have plenty of these brackets available now. I had a bunch laser cut from a local company. It’s a design that uses both factory brake reservoir bolts for better bracket security and you can use the 1 oz plastic gto reservoir or the 4oz aluminum reservoir. Just let me know because each one has a slightly different bend. Or if you want to use a different reservoir and do your own bending, let me know and I’ll leave the bracket straight(except for the bend to fit the brake master cylinder).
Thank you |
03-11-2021, 01:24 PM | #3 |
GPI Sales Consultant
PM inbound - I'll take one!
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
03-11-2021, 06:37 PM | #4 |
Drives: 02 Camaro B4C Join Date: Nov 2016
these are the hot ticket.
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
03-11-2021, 07:29 PM | #5 |
Pming you
2010 Camaro SS M6: TorqStorm Supercharger. CCP Jam Cam. Speed Engineering 1 7/8 LTs. Catless. Elite Engineering Catch Can. Tuned by Speed Tech Tuning. BMR 1/1.2 springs/trailing arms.
03-11-2021, 07:47 PM | #6 |
Thanks to all
03-11-2021, 07:52 PM | #7 |
Pm sent.
Sent from my Pixel 2 XL using Tapatalk |
03-11-2021, 08:12 PM | #8 |
07-19-2021, 08:00 PM | #9 |
Still around?
07-20-2021, 04:19 AM | #10 |
07-29-2021, 12:04 PM | #11 |
Drives: camaro Join Date: Sep 2016
I have a 2012 v-6. 60,000 miles. Anybody have an opinion on clutch and power steering fluid flushes? are they needed, how often?
