02-07-2021, 12:26 PM | #1 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Truetrac
Finally getting around to finishing up the suspension.....and 3.91's are part of it.
I see the Truetrac upgrade thrown around occasionally. For those that have it, is it worth the money for the garage queen, street driven, spirited driving old guy?
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
02-07-2021, 07:03 PM | #2 |
Old guy here with a 2010 SS and I have a Z28 Diff which is a OEM version of the trutrac and you can’t beat it!!!
Orange Krush II
02-08-2021, 12:24 AM | #3 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
TT is a bit noisier but well worth the upgrade. If you have solid diff bushings, you’ll notice it a bit more...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
02-09-2021, 07:37 AM | #4 |
Thank you.
02-09-2021, 07:39 AM | #5 |
Already have a bunch of BMR bushings in the rear, so noise is a given. Appreciate the input.
02-09-2021, 08:02 AM | #6 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
TT is on my list. I've had a similar units in other vehicles and it is better than a typical posi or locker more consistent and better out of the turns for sure. The noise I experienced was negligible, it can be minimized with the right fluid. I imagine the bushings will make a huge difference in NVH too.
Sent from my SM-N986U using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
02-09-2021, 09:01 AM | #7 |
Much better than the stock limited slip for sure. I don't have much noise with mine at all, nothing the radio can't hide.
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
