01-26-2021, 12:10 PM | #1 |
Drives: 2014 Camaro 1LT Join Date: Aug 2019
Tire Pressure Reading
Not sure if this is considered Mechanical or not, so I'll try my hand in the General forum.
How reliable are the electronic TPM sensors? I'm accustomed to checking my tires with pencil gauges, but they are hit and miss with some of their readings, and I figured if the car is doing the work for me, then why bother. |
01-26-2021, 12:27 PM | #2 |
Drives: 2SS/RS Join Date: Sep 2008
Mine normally are within 2-3 psi of what my gauge says when I check them. Sometimes the car is higher, sometimes lower. I wouldn't rely on them to get an accurate reading of exact psi, just use them as a quick reference of if they need air or if you have a flat.
01-26-2021, 12:50 PM | #3 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
I use an analog gauge for mine. Mine is usually within 1psi of the tpms when cold.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
01-26-2021, 12:57 PM | #4 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
TPMS on all my vehicles typically read about 2 psi less than any of my actual gauges
01-26-2021, 02:37 PM | #5 |
Same here, I just installed new TPMS's, old ones lasted 10yrs, and the dash readout is within 2 psi of what my dial gauge would read at the tire when warmed up or cold.
01-26-2021, 08:25 PM | #6 |
Thanks fellas
01-26-2021, 08:50 PM | #7 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
I too found the TPMS sensors pretty close to the 'analog' gauge.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
01-27-2021, 07:13 PM | #8 | |
Drives: 2011 Camaro SS/RS - 2004 Silverado Join Date: Mar 2010
I think the TPMS sensors are actually designed to show less than actual pressure. This will trigger a low pressure warning well before the ACTUAL tire pressure is dangerously low.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80 2004 Black Silverado 1500 2WD Regular Cab, Short Bed -5.3 LM7, 4L60E, 3.42, G80 2014 White Caprice PPV -6.0 L77, 6L80E, 2.92, G80 |
01-27-2021, 07:23 PM | #9 |
Drives: 2015 Camaro SS 1LE, 2014 Chevy SS Join Date: Sep 2020
Toyotas have a low pressure threshold set around 27.5 psi to set tire light. They are pretty close to car and my digital gauge at work. I wouldn't say set lower cause then tires would be over inflated a bit going off car gauges.
01-27-2021, 08:03 PM | #10 |
Drives: 2013 Camaro 2SS/RS Join Date: Aug 2020
The right front reads 24 on the dash but 42 with a TPG.
01-28-2021, 08:21 AM | #11 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Do all of your tires read correct? They weren't rotated and never paired were they?
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
01-28-2021, 09:01 AM | #12 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
I would think that 24 on the dash would give you a warning. May want to do the "re-learn" procedure. My '15s require a special tool. Not sure about your '13.
01-28-2021, 09:04 AM | #13 |
13 needs the tool too. $15 on ebay
01-28-2021, 09:34 AM | #14 |
