12-08-2020, 11:16 PM | #1 |
Drives: 2018 NFG SS 1LE Join Date: Aug 2019
to cam or supercharge
2018 SS 1LE, thinking of keeping it awhile longer and looking to give it some more power. currently has Kooks longtube headers and corsa extreme.
which route do you think I should go? really leaning towards camming it since it changes the whole demeanor of the car. let me know what you think! |
12-09-2020, 01:09 AM | #2 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
What’s your power goals?
12-09-2020, 01:36 AM | #3 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
If you're not planning to keep the car then don't mess with the cam. It'll ruin the value. And you'll never get the money back. A blower can be removed and sold. And It'll make more power more efficiently. I'd go blower.
12-09-2020, 06:42 AM | #4 |
Supercharger is the way to go! Either a Magnacharger, Procharger, Edelbrock or others. You have a few to choose from.
12-09-2020, 08:03 AM | #5 |
You'll be better off with the Supercharger. No pulling the motor, tearing the heads off, etc. Put a blower on and have it running the same weekend if you can do it yourself.
12-09-2020, 08:37 AM | #6 |
Since you have headers you will have to get a tune when you install a supercharger because of the canned tune but you can get a tuner kit which is cheaper.
12-09-2020, 09:10 AM | #7 |
Drives: SS A8, NPP, Red Hot Join Date: Jan 2019
If you have the money... Supercharger. The cam idle is awesome, but so is supercharger whine and it'll make more power.
12-09-2020, 09:59 AM | #8 |
12-09-2020, 10:04 AM | #9 |
Drives: E92 BMW M3 Join Date: Oct 2012
For me, I would go ZL1 before supercharging a 1LE. From a super charged car perspective, the ZL1 is the complete package.
If it were my car, I would go cam or trade in for a ZL1.
J-Rod Built and Matt@FSP Tuned |
12-09-2020, 10:08 AM | #10 | |
Here’s a good read. https://www.camaro6.com/forums/showthread.php?t=575903 Some kits come with provisions for port injection which really opens up the door to pushing it. At the very least it will give you a safety margin. When I was in your shoes I was heavily leaning toward the Edelbrock kit. Ultimately this is what I chose. |
12-09-2020, 10:22 AM | #11 | |
12-09-2020, 10:37 AM | #12 |
Drives: '20 ZL1 M6 Join Date: Apr 2017
I say ZL1. You'll still have a warranty, not to mention the strengthened parts. Maybe find a low mileage '18 or '19.
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
12-09-2020, 10:47 AM | #13 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
If you're doing HPDE events with any frequency, I'd go with a cam. Like someone else said, if you're not keeping it long term, go FI. You can take it off and sell it. Cam surge can be a pita to daily drive if you get the wrong cam.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
12-09-2020, 10:48 AM | #14 | |
So if you plan to supercharge your LT1, I would consider running a blend of Ethanol. If you do the LT4 fuel system it will support 8-9psi peak on E55 or so and the engine will be much happier in the long run. If you add meth on top of E or go straight to FIC +30 injectors with a LPE HPFP, then I wouldn't be afraid to push upwards of 11-12psi. Imo a cam install alone isn't worth the time or effort on this platform for what you are looking to do. It is very labor intensive and the valve train life will be greatly reduced for no more power you are going to gain. I would wager a low boost setup would outlast a cam car longevity wise. If you want to go NA then you really need to do the Heads/Cam/Intake package from somebody like Pray and it will run it's balls off. Plan on valve train maintenance every 20-30k miles or even sooner depending on how aggressive the cam lobes and spring rates are. I agree with others that moving up to a ZL1 isn't a bad idea either.
2016 NFG 1SS A8
