11-12-2020, 03:23 PM | #1 |
Drives: Black L99 2SS/RS Join Date: Mar 2014
Haven’t posted in forever and need help
Sorry it’s been years since I’ve posted and I can’t find anything via the search tool.
Anyways, I have a 2011 SS/RS One of the HID Bulbs went out, not the Halo itself but the bulb that is primarily used for night driving. For the life of me I can NOT find an OEM replacement and every auto part store tells me they have lights for the non RS that give off the yellow hue. I found some lights here and there that give off a dark blue light, but I don’t want that. I just want OEM so it matches with the other bulb. Does anyone know where to find these ? |
11-12-2020, 03:42 PM | #2 |
11-12-2020, 03:43 PM | #3 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
I put these in -
https://www.amazon.com/CAR-ROVER-D1S...omotive&sr=1-3 They have a 10000K bulb that is bluer, the 8000K is a more white light. Less than 25 bucks for 2 of them - such a deal. |
11-12-2020, 03:57 PM | #4 |
Drives: 2011 Camaro LS Join Date: Jan 2012
Diode Dynamics offers these.
11-12-2020, 06:11 PM | #5 |
Started#gottalovethatblue
11-12-2020, 06:18 PM | #6 |
Drives: 2012 Camaro SS Convertible 6MT Join Date: Jun 2020
Been very happy with my diode dynamic drls. I wouldn’t worry about being oem. Likely the life of the other bulb doesn’t have a ton of time left so might as well swap the pair.
11-12-2020, 06:33 PM | #7 |
What you need is a D1S class bulb (or set of 2 preferably). OSRAM is the original manufacturer and is considered the best. I believe that 4300k is the stock color.
OSRAM D1S
11-12-2020, 08:04 PM | #8 | |
Sporting Foole
And thank YOU for the standard “k” @4300. I had wondered what the stock rating was and hadn’t found that yet. These that I got were 8000, I’m really wondering about trying a 6000 just because? These 8000k units are bright but really I wonder if the lower number would be a whiter light and actually illuminate better? I’ve threatened to fab some mounts and stick a set of Hella 500’s with 100 watt halogens in them on the front bumper. I like those lights, they’ll light up a mile of highway! |
11-12-2020, 08:24 PM | #9 | |
I was actually thinking of going with 6ks next time too. I want something as pure white as possible. My LED DRLs are a very clean bright white and I want them to match those as close as possible.
11-12-2020, 09:26 PM | #10 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
I run the diode dynamics 6000. They are a perfect match with the P13W in the DRL. Pretty bright with a long throw at night.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
11-12-2020, 10:14 PM | #11 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
Diodes here too ...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
11-13-2020, 05:51 AM | #12 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
Phillips makes a D1S C1 bulb and Amazon Rock Auto and Ebay have them listed.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
11-13-2020, 08:28 AM | #13 |
Drives: 2014 2LT RS Summit White Join Date: Apr 2017
I did this job on my 2014; it uses a D3S instead of the D1S for a 2011, but other than that, it’s should be the same. I used OSRAM bulbs that I bought on eBay.
Here was a really helpful video on the replacement procedure: https://youtu.be/2CybG7ar0Sc There’s a few videos out there about taking the bumper off or other crazy stuff; not necessary, you can access them from the back / under the hood. It’s a little tight quarters, but do-able. |
