Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 10-30-2020, 08:29 PM   #1
choffhous
Drives: 2011 2LT RS
No Audio with iDatalink CAM1 and Kenwood DDX6706S
Welp the title says it all, everything else is working perfectly with the head unit, the OBD2 reader, everything, besides the fact that there is zero audio. Not even static.
I swear I connected all the wires correctly and to the proper one but I was reading somewhere about the blue wires but I lost the page that they were talking about.
If someone could help me out or help point me in the right direction, I would appreciate it!
choffhous is offline   Reply With Quote
Old 10-30-2020, 09:10 PM   #2
DMan918
Drives: 2012 Camaro SS Convertible 6MT
Did you try Bluetooth audio to make sure it’s not the source?
DMan918 is offline   Reply With Quote
Old 10-30-2020, 09:40 PM   #3
choffhous
Drives: 2011 2LT RS
yes, tried every audio source, and still no audio.
Old 11-01-2020, 10:27 PM   #4
bottletalk
Drives: 15 Camaro 2SS M6
are your amps turning on? Settings on the amp are correct??
bottletalk is offline   Reply With Quote
Old 03-22-2024, 04:44 AM   #5
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
Did you ever have any issue with the lock/unlock button on the head unit not working? I have a Kenwood DMX709S head unit, and the touch screen controls for the heated seats and rear windshield defroster also don't work as well. The key fob lock and unlock buttons (separate) still work.
Also note that the door unlock/lock button on the center of the head unit, seems to only work when the door is opened and it briefly gives power. After the dome light goes off (if set to door open/close), the lock/unlock center console button no longer has power; that is, unless you either turn the key in the ignition, hit the locks on the key fob, or open the door.
I tried checking all the fuses and relays, which are good and mainly in the engine bay fuse box. I even checked the 2nd fuse box that's in the driver side of the dash, on the side of the fan vent; nothing. I didn't bother going to the 3rd fuse "box" located in the trunk, under the carpet and mats, since I think there's nothing related there, not to mention it requires the trunk panels to be removed....
iMaestro dash kit buttons not working
TheBrightSide is offline   Reply With Quote
