10-21-2020, 08:33 PM | #1 |
Radar Detectors
What do you use?
Sent from my iPhone using Tapatalk Pro |
10-21-2020, 08:35 PM | #2 |
Drives: 2012 2SS Victory Red with white st Join Date: Jun 2016
I have a valentine one
10-21-2020, 09:11 PM | #3 |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
Escort Max and run the app with it and its awesome.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
10-21-2020, 09:12 PM | #4 |
Lol, if I knew the date mine was made I likely wouldn't post it out of sheer embarrassment. Mine is an old ass Cobra ESD 7000 from back when the pyramids were being built and I was still what people would consider 'young'. 5th gens didn't exist when this was produced. Hell, I doubt the Concept Camaro was even put to paper yet. It was considered an 'affordable' detector even when it was first released, at sub $100.
But it works. Yes, it picks up every leaky ass signal, shopping center, and lane departure system out there, but it has saved me a literal fortune in tickets over the years. I know when it's not joking and when there really is a traffic cop scanning, so it is still serving it's purpose for now. One day I will replace it and put it out of it's sun bleached misery. I have looked at that before and the features are insane. I know you can get it bundled with the Escort Dash Cam too (I run the VAVA 2K cam now). What does the app do? I ask because I have an Android head unit and it would be awesome to get alerts right on my stereo screen and speakers. Edit: OMG, just did some more research and learned that the iDatalink head units when used with an Rr2 brain box can integrate the Escort Max 360 detector into the head unit. SICK!
10-21-2020, 11:14 PM | #5 |
The app is linked into the radar detectors in your area by GPS so when someone's radar detector hit gets a ka or laser hit it'll put it on the apps map kinda like waze also.
If we run hard on the freeway we run all three. Also has redlight cameras location on it too. Sent from my SM-G960U using Tapatalk
10-22-2020, 12:03 AM | #6 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Here is my archaic unit. I can't drive with it on the freeway, seems like it is throwing out laser and K-band warnings more than being quiet. I'm so behind on this (and many other) form of tech. What gives all the false alarms anyhow? I turn the laser function off unless I'm in the boondocks. Guess I'll need to crack open the coin purse for a new gizmo but I don't want to spend a fortune and have the same false alarm issues.
10-22-2020, 04:34 AM | #7 |
Drives: 2010 2SS/RS, VR ext/Blk Int Join Date: Jul 2012
Uniden R3
10-22-2020, 06:39 AM | #8 |
Uniden R3
I previously had an Escort and it was good (to an extent), but when I had it, they really didn't ever support the products that they had out (I'm sure things have changed since). There was only ever one firmware update for the detector I had and then nothing. They never fixed any issues that the detector had, which could have been easily addressed in a firmware update.
2014 2SS/RS - Red Rock Metallic - Kooks Headers, Corsa Extreme, Factory Reproductions Z28 Rims, Pedders Coilovers, JDP Clutch Reservoir, Summit Racing Line Lock, GM Strut Brace, GM low profile splash guards, Roto-fab CAI, Oracle Ghosted Sidemarker Lights & Concept Mirrors, ZL1 Side Skirts, MGW Flat Stick Shifter, BMR Subframe Connectors, Eaton Truetrac, Yukon 4.11s, GForce Renegade Axles, Speedmaster79 Diff Cover, Offset Diff Bushings, Every Suspension Bushing Front & Rear Replaced with BMR Poly Bushings - 421HP 412TQ
10-22-2020, 06:46 AM | #9 |
Valentine one. Saved my ass many times!
10-22-2020, 06:56 AM | #10 |
Drives: Chevy Camaro hwse 2018 GMC Sierra 1 Join Date: Jun 2019
Valentine one
10-22-2020, 07:01 AM | #11 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Escort Passport 8500. Had it since I was 16. 32 yes old now. It’s been good to me.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
10-22-2020, 08:35 AM | #12 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
Escort 9800ix
10-22-2020, 09:13 AM | #13 |
Drives: 2014 camaro SS Join Date: Jan 2019
I always travel with waze
10-22-2020, 11:25 AM | #14 |
Yeah, Waze has definitely helped me out as well.
