10-12-2020, 04:45 PM | #1 |
Drives: '10 RJT,'95&'14 Vette Join Date: Feb 2009
Roof Ditch Rails Fading and Cracking
The body colored "Roof Ditch Rails" on our 2010 Crystal Red Red Jewel Tintcoat RS fixed roof (delivered May 2009) are deteriorating.
By that I mean, the color is fading and starting to get small cracks in them. The car has been extremely well cared for - washed and waxed at least 2X month. I was garaged for the first 5 1/2 years and outside since then. I started to notice this about a month ago. No amount of polishing or light compounding is bringing them back to life. A search has turned up nada. Its raining so I can't really get any good pix of it. Anyone else noticing this happening on theirs? Thanks.....
"As ye sow, so shall ye reap" - Me
Mine at sunset |
10-12-2020, 05:10 PM | #2 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Mine started doing this a couple months ago. It’s not bad yet however I’m sure it won’t take long and it will be. Looks like a spider web on the ditch mounding.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
10-12-2020, 05:18 PM | #3 | |
Installation seems like just popping out the old ones and pushing in the replacements.
Mine at sunset |
10-12-2020, 07:14 PM | #4 |
Not hard to do. I’ve looked into changing mine but I haven’t gotten around to it yet. I should have picked them up already cause I just dropped a splitter off at the shop today to get painted. Could’ve done both at once... but I didn’t.
10-12-2020, 07:54 PM | #5 |
Mine are doing the same thing. I think I read somewhere it means the clear coat has failed. I figured eventually Ill find out how much it cost to repaint them both. Nothing wrong with the rubber itself.
2013 Camaro SS/RS, Stainless Power long tube headers with HF's, Air Raid CAI, Solo Mach XL cat back, BC Racing coil overs, Elite Engineering catch can, Ferrada Forge 8 Wheels, Windows tinted at 20%, Tuned by Dyno Steve.
10-13-2020, 09:30 AM | #6 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
This stuff
10-13-2020, 07:39 PM | #7 |
Drives: 2014 camaro SS Join Date: Jan 2019
sunlight deteriorates everything. UV is your car finish's enemy. if you can't garage it, buy a bag. great for all seasons
10-13-2020, 07:45 PM | #8 |
Drives: 2015 Camaro Join Date: Aug 2018
Just wrap them. When/if the color fades again, just rewrap.
10-13-2020, 07:50 PM | #9 |
Stovebolt BluFlame 6
Drives: '12 2LT/RS, IBM; '20 Traverse Prem Join Date: Oct 2011
All good suggestions, above. I especially like the idea of wrapping with carbon fiber vinyl.
I've noticed this on our IBM 2012RS. Frustrating and just hope it isn't a sign of things to come with the rest of the body paint. |
10-13-2020, 10:58 PM | #10 | |
Drives: 2SS/RS Join Date: Sep 2008
As for the op, they are made out of cheap plastic and is pretty well known to need replacing after a time. There are a few threads on here about it. |
10-14-2020, 06:29 AM | #11 |
So even if they are cheap plastic, you cant just repaint them vs replace?
10-14-2020, 10:04 AM | #12 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Never thought about these going bad. I’ll have give mine a closer look.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
10-14-2020, 10:16 AM | #13 |
If you can remove them without damaging them, sure, but good luck with that. The issue I had and have seen on others, isn't really the paint. It's that the sun makes them brittle and have cracked or broke.
10-14-2020, 11:48 AM | #14 |
Drives: 2010victoryred2lt Join Date: Mar 2011
Had to replace both of mine last year
