10-03-2020, 11:17 AM | #1 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Boost pulley question
I have a question, but first a reminder of the build that is taking place.
Magnuson 2650, 9.17 lower pulley, NW103 and BG, ARH 2" with no cats into stock muffler, Lingenfelter check valve, DSX aux pump, lastly BTR stage 2 with 38%. Originally I was gonna do a 90mm upper, but wanted to know if there is enough injector to go one size smaller upper and be safe. Tunes are 93 and MS109.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
10-03-2020, 02:34 PM | #2 |
Drives: 2017 A10 ZL1 Join Date: Jul 2011
That's a good question for your tuner.
10-03-2020, 03:07 PM | #3 | |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
From what I found, you should be around 15psi with that combination, and that is the max your fuel system can handle. You will find the answer in this video: https://www.facebook.com/jannettyrac...5606504085606/
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
10-05-2020, 08:47 AM | #4 |
Petro-sexual
Your tuner should have good insight, but it seems like if you might be able to run to around 850 with a cam and low side mods'. I think CSP's old ZL1 (which he just sold) was running to around there, with no supplemental fuel to the high-side. I believe he was running the low-side, and without meth', was getting to about 850-or-so. I wouldn't know, but I would guess that with your lower, a cam, and a 90mm-upper, you'd probably be around 15-psi or so. That's only a guess based off of what I've read about and seen videos of.
10-05-2020, 08:56 AM | #5 |
How much boost are you running now? 90mm and the 9.17 lower I would guess around 15-16 psi. You can definitely run a some more but we've ran into knock around 20 psi. It would hit around 18 in the midrange and knock.
10-05-2020, 09:03 AM | #6 | |
2016 NFG 1SS A8
10-05-2020, 09:39 AM | #7 |
Don't know as car is being done now. Turns out, Magnuson forgot to put the pulley in the box, so i fiugred if i have to get them to send one, i should see if anyone got by with the 85mm with same mods. I know the 90mm will be ok.
10-05-2020, 01:52 PM | #8 |
Petro-sexual
OH... I thought he wasn't running meth for that 800-RWHP contest set-up. My bad. I know I remember seeing the meth lines on later parts of the build. I do recall the interchiller, like you said. He posted a few good ones after the C8 stuff started, but my interest fell, too. If I find the video, I'll post, not that it really matters, so never mind, hahaha. If someone's interested, I can go look.
10-05-2020, 03:20 PM | #9 |
Dyno Show Queen LOL
9.17 and 3.5
8.6 and 3.25 8.3 and 3.0 usually these combos are between 18 to 19 probably depends on cam. those will net that 825 to 850 mark on 93
10-13-2020, 04:37 PM | #10 | |
Which pulley combination did you end up using, and how much boost is it making?
2018 Camaro ZL1 A10
10-13-2020, 09:26 PM | #11 |
Tuner suggest we stick with original plan of 90mm upper since I have the 15% lower. Unfortunately still waiting for the pulley to get to us. Cam is in, new oil pump is on. Interesting he said the new pump feels 10lbs heavier than the original. He didn't weigh it, but I get the point it feels more robust. Wonder what they changed to make it feel that way.
10-14-2020, 06:07 AM | #12 | |
Hopefully you will get it soon. Keep us posted.
2018 Camaro ZL1 A10
10-26-2020, 08:55 PM | #13 | ||
Drives: 2022 Camaro ZL1 Convertible A10 Join Date: Aug 2012
CSP/Andrew's ZL1 made just over 800 rwhp SAE with: 1. Roto Fab Big Gulp intake 2. Kong Ported LT4 blower 3. NW 103mm TB 4. Kooks 2" headers 5. Custom camshaft +32 Fuel Lobe 6. Ported TSP heads 7. Interchiller 8. 93 octane pump gas only, NO meth NO E85 Last edited by JFWJR179; 10-26-2020 at 09:00 PM. Reason: to correct numbering, omission |
10-26-2020, 09:55 PM | #14 |
I think you'll see around 14 psi with the 90 and the 9.17. Every 5mm is about 2 psi of boost, maybe 2.5 depending on heads, cam, headers, etc. if you decide to go smaller pulley at some point. Your build is exactly whats in my Camaro now except it has 1 7/8 headers, no cats, same cam and of course 2650. Its on only 14 psi and 22 degrees of timing and made 847 and 790. Recently went 9.40@147 with its new owner. We are going to put some more timing in it in the upper RPM range and pull some timing at the launch, can't get it to hook in these cooler temps. If all the stars align Saturday I think it can run 9.20s. So buckle up, your gonna have a killer ride with shit load of power.
