09-23-2020, 04:33 PM | #1 |
Drives: 2018 Camaro SS 2SS Join Date: Sep 2020
What is this??
2018 SS 2SS with Stock NPP exhaust
Several seconds after starting up this sound starts, random intervals around every 30 seconds. Its apparently some kind of metal expansion from heat. It also makes the sound as often when turned off and cooling down. Dealer replaced the entire exhaust but the problem still persists, I have to verify that they replaced the cats as well, but I believe they did. https://youtu.be/Jmuvau0Ce_0 |
09-23-2020, 05:19 PM | #2 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
Ever seen the movie Gremlins?
You got em. |
09-23-2020, 06:27 PM | #3 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
Mine makes cooling down noises but nothing like that...i dunno
09-23-2020, 07:41 PM | #4 |
Just going off of whats been replaced, I think headers or gaskets between headers and exhaust possibly. Also possibly oil pan issue?
09-23-2020, 09:44 PM | #5 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
I guess I would start with a scope and listen and try and narrow it down to where it's happening. Sound almost like some kind of heat shield with possible loose bolt(s).
09-24-2020, 07:59 PM | #6 |
Is there an official scope for automotive problems? Or can I rig something up?
09-24-2020, 09:01 PM | #7 |
Drives: 2020 LT1 Join Date: Nov 2019
Its called heat soak.
Posts like this are why I get banned everywhere I go on the internet. Last edited by ThirdGenNut; 09-24-2020 at 09:57 PM. |
09-26-2020, 07:30 AM | #8 | |
Drives: 18 Camaro 2SS, 07 Saturn Ion Join Date: Apr 2018
OP, I get the same sounds. It's expansion, just like you said. Nothing to worry about.
Ordered from Becky D __ 2018 2SS Silver Ice Redline 6MN, NPP, MRC, GM CAI
10-02-2020, 04:26 PM | #9 |
I've pinpointed the sound at the passenger cat. By tapping it while its cooling down, I can get the ping to trigger. I just can't tell if its internal to the cat or the points of contact from each side, or even the welded bracket mount on the top side of the cat.
10-02-2020, 05:09 PM | #10 |
Drives: 2017 Camaro 2SS Join Date: Jul 2016
Could be condensation from the a/c dripping on it. Can't believe a dealer replaced the entire system for what seems like obvious heat noises.
2017 2SS A8 TSP LT's, ported msd/95 mm, e85
10-02-2020, 06:15 PM | #11 |
They replaced the exhaust for a cracked weld that holds the two side together. But it looks like they didn't replace the cats
10-11-2020, 10:21 PM | #12 |
Owning SSes for 50 Years
I've never heard anything like that in any car I've ever owned. Most will kind of tick when cooling but not a loud click like that.
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars: 1966 Chevelle SS 4M, 2010 Corvette 6M 1968 Dodge Charger R/T Auto 2012 1SS 6M 1982 Corvette Auto 2010 1SS 6A 1984 Corvette Auto 2016 2SS 8A 1999 Camaro Auto 2017 HBM 1SS 1le 2002 C5 Corvette 6M 2018 2SS 2006 Corvette Auto 2023 Camaro LT1 |
10-12-2020, 06:05 AM | #13 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
Most all cars i had make them popping sounds once i am in the garage. My 2010 5.3 Colorado did it the most.
10-12-2020, 01:40 PM | #14 |
Drives: 2022 Vivid Orange Metallic LT1 Join Date: Mar 2020
My car makes the same sound. It does it after shutting the car off and it is cooling down.
