08-03-2020, 10:08 AM | #1 |
Drives: 2010 Camaro 2SS Join Date: Mar 2018
Trans cooler sold by GPI???
Anyone use it https://gwatneyperformance.com/produ...tallation-kit/ How was the install?
GPI SS3 cam with top end goodies,Circle D 4c 3800 w/Derale trans cooler kit sold by GPI,3.90 yukon gears,Kooks long tube headers,Roto fab cold air intake, Corsa extreme 3" cat back, Dyno tuned by Andrews Auto Georgetown MI, Heritage Grille, T4 splitter with under tray, Anvil spoiler,MRR 228 reps with Nitto NT555G2 tires 315 rear 275 fronts,BMR poly bushings,HD Diff cover from RDP,Raytech install kit
08-06-2020, 08:36 PM | #2 |
Drives: 2010 ss/rs 6 speed manual Join Date: Aug 2013
I haven’t but it looks like a nice unit
2010 camaro ss/rs, standard 6 speed, ls3 motor, bmr subframe connectors, jba 3” competition Exhaust, stainless works 1 7/8" headers, adm cold air intake, hurst short throw shifter, bo white ported tb, mishimoto aluminum radiator, mishimoto oil cooler.
08-10-2020, 08:15 AM | #3 |
Well I just bought it and a 3800 stall circle D from GPI yeehaa
08-10-2020, 09:59 AM | #4 |
Awesome you should update this thread with your thoughts on the trans cooler. I’m in the market for one sometime down the road
08-10-2020, 11:32 AM | #5 |
I will definitely do that!!!
08-10-2020, 09:38 PM | #6 |
Where are you going to mount it??
Orange Krush II
08-10-2020, 10:02 PM | #7 |
That is a good ? I have to consider when I get around to this.
There is two screw points just under the hood latch that can be used for mounting a cooler. I have just mounted my oil cooler there. My mishimoto oil cooler has mounting holes top and bottom. I used the top mounting to mount that cooler I might be able to get another cooler mounted to the oil cooler.
08-11-2020, 07:04 AM | #8 | |
08-11-2020, 08:45 PM | #9 |
Drives: 2010 Camaro SS Join Date: May 2018
This is the cooler GPI installed when they did work on my car (SS3 Circle D 4f). So far so good. I've been up thru the Blue ridge mountains on the back roads (real curvey-up & down). The highest it read was about 185-190.
08-11-2020, 09:48 PM | #10 |
Location
Where an how did they mount it???
Orange Krush II
08-12-2020, 06:26 AM | #11 |
That is great to hear!! I did that ride on my motorcycle but really want to get back there with the maro!!
08-12-2020, 05:50 PM | #12 |
That is too small for a stand-alone cooler.
You will want to install that on the OUTPUT (to trans) side of the rad. TRANS--->RAD--->COOLER-->TRANS |
08-12-2020, 07:59 PM | #13 | |
Also which hose out of the radiator is the return line to the trans? Pass side or drivers side hose?
08-12-2020, 08:28 PM | #14 | |
Drives: '23 LT1 A10 Join Date: Oct 2015
Did he F up? |
