07-07-2020, 07:33 PM | #1 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
My TC Shudder returned
Had the flush done under warranty middle of last year, I think around June, I can't remember exactly when. Either way though its back.
Should I try to push for a new torque converter? if so, how? |
07-07-2020, 07:37 PM | #2 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
You had the latest fluid and flush procedure done? No damage to the torque converter at that time?
07-08-2020, 02:14 AM | #3 |
07-08-2020, 05:10 AM | #4 |
Drives: 2016 Camaro SS Join Date: Jan 2019
I had mine done right before the new procedure and it was ok for barely past the period they said to drive it. When I went back they just started the new procedure (tech said I was the first Camaro) and it's been fine since, about 9k miles. Go back again.
07-08-2020, 08:30 AM | #5 |
Assuming you are still under warranty, then your dealership should do the new fluid and flush procedure along with replacing the torque converter if needed. That's exactly what they did in my case. I didn't even have to ask about the converter, they just saw that it was damaged and replaced it
07-08-2020, 10:28 AM | #6 |
Drives: 2017 2SS F1FTY Join Date: Feb 2020
This whole A8 situation is unreal.
07-08-2020, 11:04 AM | #7 |
There's nothing new as far as I can tell, unfortunately several cars on the original torque converter will still hit the (same) problem. New TC + new 2019 fluid = success, if either is missing, the shudder can be expected with some nonzero probability.
Now if that "equation" stops being true, that would definitely qualify as unreal.
07-08-2020, 11:17 AM | #8 |
What TSB was performed on your car?
07-08-2020, 12:50 PM | #9 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Agree and that’s why I traded in my 2016 A8 SS for a 2019 M6 SS.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
07-08-2020, 01:17 PM | #10 | |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Before I sold my 2016 SS I had the latest flush procedure (with the new Mobil 1 product) and seemed to fix *most* of it. I have to believe some damage to the TC already occurred though |
07-08-2020, 11:55 PM | #11 |
Drives: 2017 2SS, 2023 3LT RS, 2011 2LT RS Join Date: Aug 2014
had my TC replaced 2 years ago, no issues since. 35K miles on the new T.
'17 2SS ■ HBM '23 3LT RS ■ Rapid Blue '11 2LT RS ■ Red Jewel |
07-09-2020, 09:39 AM | #12 |
Just had my Vet done before it goes out of warranty. So far so good, GM never had to do my Camaro since it was modded to the point they wouldn't even look at it. But its still doing great after 100s of passes down the track and 13000 miles and the tranny is bone stock.
07-15-2020, 06:05 PM | #13 |
Welp, I got good news and bad news..
Bad news first: ...My Powertrain Warranty expired... I for some reason thought it was until 75k miles, it was only until 60k and I'm at 61k miles. Car is still at the dealer regardless. I have an extended warranty that I paid for but I'll have to come out of pocket alittle for whatever repair is deemed necessary. I'm also 2 weeks out just for diagnosis. I have a loaner. Now for the good news: ...My Powertrain Warranty expired...I can now do whatever the hell I want with my car. I'm thinking of an E85 Tune as well as intake and full exhaust and maybe - just maybe a cam. Not sure on the cam. I may end up just going S/C That all asside, I've heard of some members replacing the TC and doing a tune for a permanent fix to this issue. What exactly was done? Did they just tune out AFM or was something more tuned? I dont really want to stall my car. I put a stall in my 4th Gen and it doesn't really appease me for a street driven car. Or should I just hold out for a ZL1? |
07-15-2020, 08:47 PM | #14 | |
As to the tune and upgrades, Ted Jannetty did mine and there is much more to the trans tune than disabling AFM. A good tune transforms the A8 into the great transmission it is, I have zero issues with it apart from the paddle shift delay (but that is a design limitation). I'm sure others can also do a great job, and hearing that you're considering flex fuel, cam and/or FI, I for one wouldn't mess with the TCM/ECM/FSCM tune but get that done by a pro shop.
