Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 06-18-2020, 08:00 AM   #1
KevinHoward8509
Drives: 2014 camaro ss 1LE
Launch control on a 2014 1LE
Got a quick question on launch control on my car.
I know how to activate it but my question is can you adjust the RPM"S in which it holds at?
my car leaves at 4k which is to high for street i wanna get it down to like 32-3300.
My car goes to the tuner in a month to get tuned for E85 and i was going to have him tune that down if that is possible.
KevinHoward8509 is offline   Reply With Quote
Old 06-19-2020, 10:15 PM   #2
Scotty D
Drives: 2014 1le 1SS CRMT
My 2014 1le dont have launch control ?!?!?
Scotty D is offline   Reply With Quote
Old 06-20-2020, 03:03 PM   #3
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
All SS models came with launch control. Put it in comp mode, floor it and the RPMs will stabilize around 4-5k, then dump the clutch.
And for OP it's probably easier just to learn how to launch it yourself with no launch control.
2014 1SS/1LE
AGP 57/57s, E85 + meth injection, Monster triple, ZL1 diff swap, Z28 coilovers
AGM 1LE is offline   Reply With Quote
Old 06-20-2020, 03:14 PM   #4
Scotty D
Wow never knew that
Old 06-20-2020, 04:11 PM   #5
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Your better off learning to launch it on your own, you’ll just fire the tires otherwise.
HOJO is offline   Reply With Quote
Old 06-20-2020, 04:38 PM   #6
Scotty D
I can launch my car fine but I never knew that we had that option built into the car
Old 06-21-2020, 08:32 PM   #7
TWOFORTYZ
Drives: 2015 Camaro 1SS 6M
The launch control is more or less burnout control. Very slow, probably a full second worse than a good launch. I did a test next to a tesla last night, launch control gave him 3 car lengths, a normal launch put me ahead right off the line.
Edit: testing isn't racing.
TWOFORTYZ is offline   Reply With Quote
