Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Z/28 Forum - Z/28 Specific Topics
Old 06-14-2020, 07:26 PM   #1
JUSTIFIED
JUSTIFIED's Avatar
Drives: 2015 black Z/28
Small groove in CCB rotor
Hi All -
I've developed a small groove in my front left rotor. Am soon taking it in to have it checked out, but wonder if anyone else has seen anything like this?
Pads appear to be in good shape. It could something lodged between pad and rotor, but that's hard to fathom.
Appreciate your insights.
-John
JUSTIFIED is offline   Reply With Quote
Old 06-15-2020, 07:36 AM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I’d say if you can’t feel it with your finger nail you should be good to go.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 06-15-2020, 08:24 AM   #3
JUSTIFIED
JUSTIFIED's Avatar
Thanks. It's very shallow and I can barely feel with my finger nail. Really odd. No clue what's causing it.
Old 06-15-2020, 08:40 AM   #4
steakmaker
steakmaker's Avatar
Drives: '10 Camaro SS,Jeep Commander Hemi
line on rotor
Originally Posted by JUSTIFIED View Post
Hi All -
-John
John,
I would say there was a small stone pebble,for a short time between your rotor & pad,it only lasted a few rotations then was pulverized and ended up as dust,It doesn't look serious,Rotor certainly can be turned,I'd do both rotors to keep the braking balanced. Happy cruising !
steakmaker is offline   Reply With Quote
Old 06-15-2020, 09:53 AM   #5
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 ZL1 M6 vert
Originally Posted by steakmaker View Post
John,
I don’t believe carbon rotors can be “turned” as steel rotors. Some special diamond blades are used if there’s even any shops that can. I’d say if the pads look good then just run it and keep an eye on it. If your tracking it, I’d replace.
SIM GhostrdrZ is offline   Reply With Quote
Old 06-15-2020, 11:37 AM   #6
steakmaker
steakmaker's Avatar
carbon fiber Rotor
You're correct,I forgot it was a carbon fiber rotor,my bad!
Old 06-15-2020, 02:15 PM   #7
'10CamaroDude
Drives: 2010 Camaro LS
You can't turn slotted and/or drilled rotors regardless of what they're made of.
'10CamaroDude is offline   Reply With Quote
Old 06-15-2020, 02:29 PM   #8
SIM GhostrdrZ
Good point
Old 06-15-2020, 03:42 PM   #9
JUSTIFIED
JUSTIFIED's Avatar
Thanks, all! Am not overly worried and do not track it Will keep an eye on it.
Old 06-15-2020, 03:44 PM   #10
Zslash28
Jumanji
Zslash28's Avatar
Drives: '14 Z/28 - AGM - No A/C
Well, it can only get better from here.
Keeper of the 5th Gen Z/28 Registry.
Registry Facebook.
Follow: @5th_gen_z28_registry
I track wrecked Z/28s Total lost -41
Zslash28 is offline   Reply With Quote
