06-12-2020, 12:34 PM | #1 |
Drives: 2014 camaro ss Join Date: Oct 2018
Best performance shops for tune and header install michigan
I'm getting headers in about 2 weeks. Does anyone have any recommendations where I should go to get them installed and a tune? I live in Michigan. I got a quote from vector motorsports and they want $750 to install the headers and $750 for the tune. Would I be better off getting a tune from someone like Jannety Racing or Dyno Steve. My mods are going to be headers, high flow cats, exhaust and cold air intake.
06-12-2020, 03:03 PM | #2 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Of those I’d two pick Jannety unless you can find a shop that won’t rip ya off on the install. 750 is what I paid to have my clutch changed lol
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
06-12-2020, 04:22 PM | #3 |
06-12-2020, 05:06 PM | #4 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
That's too much for the install by about double. It's an easy job.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
06-12-2020, 08:14 PM | #5 |
Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
you don’t need a performance shop to put on headers, it’s as basic as basic can be. do it yourself and get a tune from janetty.
if u don’t want to do the header install yourself take it to a decent exhaust shop and save yourself a lot of cash. |
06-13-2020, 07:12 AM | #6 |
Drives: 2010 Camaro SS Join Date: Oct 2010
Give Walsh Motorsport in Wixom a call. They do both installs and tuning. They have done a twin turbo setup on my friends Camaro and tune / pulley on his V. Also did some suspension work on my Camaro while I had it. Was very happy with them.
Obviously got other work done at Livernois and have been very happy with them too.
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete Roto-Fab Intake Stainless Works 1 7/8" Long Tube Headers Corsa Exhaust Last edited by Agent WD-40; 06-13-2020 at 07:42 AM. |
06-13-2020, 04:45 PM | #7 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
Livernois...…...
06-14-2020, 10:19 PM | #8 |
I dont want to do it myself because I don't want to mess up and damage the engine.
06-15-2020, 09:48 AM | #9 |
So I called livernois motorsports and they are saying if I want them to do it they have to install a lower temperature thermostat and new spark plugs and wires. That doesn't sound right to me. This is the only place I've heard this from.
06-15-2020, 05:25 PM | #10 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Just do it yourself or with a buddy. it’s really easy. It sucks, but it’s easy. The only time I paid for headers install was for my C6Z. Never again, unless I’m feeling lazy
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
06-15-2020, 06:50 PM | #11 |
Most run a colder plug after doing mods. The wires they might be quoting you because if they are old the may be brittle and break on removal. Colder tstat isn't required but also is a good idea.
06-15-2020, 09:09 PM | #12 |
I thought they were just trying to sell me something. Before I do anything I research it extensively. And I seen or heard no where that you needed a colder thermostat and new plugs and wires to do headers. But that does make sense about the wires. Now my header install is going to take longer because now I have to start my research on colder thermostats and wires.
06-16-2020, 07:06 AM | #13 |
Drives: 2012 Camaro SS Join Date: Jun 2019
I've dealt with Livernois quite a bit, they've always steered me in the right direction. When was the last time you changed your plugs? Are they due for a change?
Also, are the wires they mentioned spark plug wires or O2 sensor wires? Not sure what the laws are in Michigan, but some LTs need O2 sensor extensions if you want to keep them after the cats.
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
06-16-2020, 07:18 AM | #14 |
Drives: 2014 SS Convertible Join Date: Jun 2015
I went to Vector for a cam job and was not impressed at all. A year later my rocker arm bearing exploded because they didn't bother upgrading them.
Livernois is supposed the bees knees, but when i spoke to them about having work done it was very dismissive and extremely over priced. Also they lock their tunes which I don't love. After I did my LSA conversion i took the car to Lidio at Alternative Auto Performance in Chesterfield for the tune. They are mainly a ford / dodge shop, but he knows his stuff. That being said.....if it was me......I'd save more money and drop it off at a shop for a cam as well. If you're gonna pay $600 for a tune might as well make it worth while. Headers and an intake aren't going to net you a lot of power. TLR.....don't trust vector......Livernois is for the rich people........
Engine: LSA Conversion, Ported Heads, 1 7/8 headers, VMS 2.5 Cam, Roto Fab intake, ADM Scoop. BMR engine mounts, 3.91
628/525 Suspension: Koni orange, (BMR everything) 1" drop springs, toe rods, trailer arms, non adjustable LCR, FE4 sway bars, sub frame connectors, delrin sub frame bushing and upper control arm bushings. Front bushings. |
