![]() Drives: 2017 ZL1 and 2018 SS 1LE Join Date: Oct 2015
Anybody else have this issue?
My car gets all this black soot almost like brake dust all over it. I’ll wash the car and after 50 miles the back has this soot all over it. I don’t know whether the stuff in the door jambs and near wing are related but the back of the car turns black almost instantly and is definitely coming from exhaust. I don’t know if it’s oil related or not, but I do notice about 1 quart of consumption every 1600-2000 miles depending on how drive it, multiple Chevy dealers have said the consumption is within range. But again, I don’t know if it’s related. Completely stock 2017 ZL1. The pictures don’t show very good, but it builds up a lot of this stuff.
![]() Drives: Buick Grand National, BMW M5 Join Date: Nov 2019
I have also been experiencing the same.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
It may be dirt and grime off of the roads. My ZL1 gets that way too and the outer tailpipes are sooty. The 2016 SS I had was real bad about looking like your ZL1 especially in the door jambs. I was constantly cleaning them especially since the SS was white. It seems with my ZL1 when it rains a lot the dirtier it gets when I do drive it.
![]() Drives: 2004 Honda Civic+2011 Camaro 2SS Join Date: Sep 2013
do you have any wax/sealant/ceramic on the paint? Wouldn't think it would stick like that if so but I could deff be wrong
![]() ![]() Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
Could it be brake dust?
![]() ![]() ![]() ![]() ![]() Drives: 08 Tiburon GS, 2018 Camaro 2.0T Join Date: Sep 2017
Not getting any in my I4
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
--------------------- Order WDGHKX 1100 - 5/08/2018 | 3800 - 6/18/2018 2000 - 5/09/2018 | 4200 - 6/21/2018 3000 - 5/28/2018 | 5000 - 6/27/2018 6000 - 6/29/2018 |
#7 |
![]() Drives: 2019 Chevrolet Camaro 2SS Join Date: Jul 2019
The only soot I get is on my tailpipes
#8 |
Not sure how soot from the exhaust could get as far forward as the door jams. But, I don’t know. Mine gets that really fine dust like that too, but nor nearly that much. I’m gonna say it’s most likely brake dust. In the one pic where I can see the rear wheel, it looks like it is coated as well. It does seem excessive though if you accumulate that much in just a short amount of time. Have you checked to see if your front brakes are dragging too much? I’d probably jack up on front side and make sure the wheels spin freely. How are the pads and rotors?
#9 |
![]() ![]() ![]() ![]() Drives: 1970 chevelle Join Date: Aug 2011
did you put tire shine on the tires?
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car 2015 Z06 Z07 Daytona Sunrise Orange Metallic Dads Car 2013 ZL1 vin 963 Crystal Red Tint Coat/Black Wheels Exposed Carbon Fiber Insert 6 Spd Manual |
#10 |
Could be brake dust but not sure. Seems like my 2010 SS was that way too if I remember correctly. I do know that my wheels on the ZL1 sure get dusted after cleaning them only after about 100 miles or so.
#11 |
Too much tire shine will definitely coat the sides of the car and rear. If I do use some it is a very light coat.
#12 |
To collect on the front of the rear spoiler like that I would suspect an environmental or road source.
#13 |
![]() Drives: 15 SilveradoLTZ,162SSVert BlazerRS Join Date: Dec 2015
It happens to Mine, Its Brake Dust!!!!!!
#14 |
![]() ![]() Drives: Former 2016 Camaro 1LT Join Date: Jan 2017
I get it too. What is interesting though is I starting getting it only after with my new Stance 20" wheels and tires. The wheels are 10.5 wide and the tires are meant to be "flush" with the wheel wells but actually protrude by about 1/4" from the wheel well (measured at the top).
My previous stock wheels 8.5" were much narrower and were inset quite a bit from the wheel well. More negative offset. I did not experience this dust and grime nearly as much with the narrower wheels and tires. I suspect the closer your tires are to the edge of the wheel wells, with wider tires, the soot, brake dust and road grime are more apt to get on the car. My car also before when I went through a puddle or drive on wet roads did not get nearly as dirty as it does now.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
