04-30-2020, 08:23 PM | #1 |
ALWAYS-N-BOOST
ZLE VS ZL1 DRAG COEFFICIENT SPEED
At what speeds does the Drag Coefficient start to play a role in the two Models
Debating ZL1 vs ZLE I prefer the Aggressive looks of the ZLE over the ZL1 - yet want to be sure to select the vehicle best suited for my personal needs. **Roll Races and 1/2 Miles Airport Events** So at what speed will the ZLE start to show the Drag Coefficient? If in mexico doing a roll say 60-140 will there be a significant difference? Or does it not play a role up until Numbers like 150-160 which I rarely hit
2012 1LS M6 Black-Sold 2013 2LT M6 BluRay- Sold 2015 1SS 1LE M6 Black-Sold 2021 ZLE A10 Riverside Blue - Awaiting Arrival 01/10 |
04-30-2020, 08:27 PM | #2 |
Drives: 2018 M5 Join Date: Nov 2019
I will say at about 178 to 180 the ZLE hits a brick wall. It might go faster than that given space but I doubt it would be much more if any.
04-30-2020, 08:38 PM | #3 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
I don’t have the formula for coefficient of drag on these cars but I’ve done 1/2 mile events and I can tell you that track cars with aero ARE affected and are slower in the 1/2 mile than their counterparts. You will be 140+ mph in the 1/2.
04-30-2020, 08:41 PM | #4 |
a standard ZL1 in a straight line definitely has an advantage especially above 120mph...it is significant on a road course long straight.
04-30-2020, 08:44 PM | #5 |
Basic internet search suggests that aero begins to have a drag effect at speeds of 100-120 kph or about 60-75 mph.
04-30-2020, 08:54 PM | #6 |
ALWAYS-N-BOOST
Correct me if im wrong, so in a race between the two models the ZLE will start to fall off starting at 60MPH and the ZL1 will pull ahead the rest of the way to top speed
04-30-2020, 08:59 PM | #7 |
No. I roll raced a auto ZL1 at Ennis at a club day. I won 2 out of 3 with my manual ZLE. We crossed the start line at 30 mph and were well over 130/ 140 at the end.
04-30-2020, 09:00 PM | #8 |
30 mph rolls benefit the manual more than the auto.
04-30-2020, 09:25 PM | #9 |
Drives: The DSSV Twins: ZR2 and ZLE A10 Join Date: Oct 2019
Let me try something here:
Drag force = drag coef x speed^2 So horsepower used against drag = drag coef x speed^3 If both cars are using same power at top speed then Drag coef zl1 x top speed zl1 ^ 3 = drag coef zle x top speed zle ^3 If zl1 top speed is 202mph and zle is 178 then drag coef ratio is (178/202)^3= 0.684 Meaning the zl1 has 68.4% of the drag of the zle or the zl1 gets to use 31.6% more torque accelerating rather than fighting aero drag. If at 101mph, the zl1 is at half top speed, meaning it's using 1/8th (drag power is cubic) of its power to fight drag which 650hp/8=81hp. This speed would require the zle to use 81hp/.684=118hp. So at 101mph, it's as if the zl1 has 118hp-81hp=37hp more than the zle. Super oversimplified, but maybe a good ballpark estimate? |
04-30-2020, 09:28 PM | #10 | |
ALWAYS-N-BOOST
I can dig it - math seems logical
04-30-2020, 09:38 PM | #11 | |
Edit: I say that because I know up to 140 I could stay ahead but he was gaining, fast. |
04-30-2020, 10:05 PM | #12 | |
04-30-2020, 10:13 PM | #13 |
... although I'm seeing articles claiming the zle tops out at 190mph, so that would be about 54hp difference at 150mph
04-30-2020, 10:14 PM | #14 |
From 30 the ZLE jumps out about 2 or 3 car lengths, manages to hold that for a while but as speeds increase the ZL1 is visibly catching up quickly. From 50 MPH it's just which driver hits the shifts and again if you are ahead at 145 or so the ZL1 is obviously pulling harder. Just my experience with roll racing the ZLE, I am a pretty good shoe with a stick. There is no doubt in my mind at 145 plus the ZL1 is going to embarrass a ZLE on the open road. Of course the ZLE is going to embarrass the ZL1 on a road course given equal drivers. The cars have two very different purposes. Why I let off at 150. No sense in pushing the cars that much in a roll race when the outcome is obvious. Just needlessly endangering all involved after that speed.
