04-28-2020, 11:24 AM | #1 |
Drives: 2019 2ss 1LE Join Date: Mar 2019
ZZperformane pillar pod install question
I cant find any videos on the install and I know its simple I'm just a little worried about the air bag in there. For anyone that has installed do I just unplug the sensor or do you leave it plugged in and pop it off the original pillar? I just don't want this thing to go off on me.. anybody with any knowledge on air bags can help too
04-28-2020, 10:48 PM | #2 |
Drives: 2018 ZL1 Hyper Blue A10 Join Date: Jan 2018
I disconnected the battery before removing, just take your time and be careful with the mic up top.
04-29-2020, 12:27 PM | #3 |
Drives: 2017 50th Camaro SS Join Date: Jul 2016
I didn't disconnect the battery. Just pop it off with some trim tools if you have them and disconnect bungie and mic. It's pretty straightforward. Once you pop the pillar you'll see what needs to be done.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
04-29-2020, 03:34 PM | #4 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Yep, just did this for dash speaker replacement. There's no airbag sensor in there that would set the bag off. There is the bag itself - just don't poke a hole in it. I get your trepidation - I am not fond of yanking off any panels. Here the two gotchas I found:
Matt Miller
2020 SS 1LE |
04-29-2020, 03:47 PM | #5 | |
05-26-2020, 08:32 PM | #6 |
Drives: 2019 1SS M6 Join Date: Jun 2018
Plenty of room for wiring? Installing a couple gauges this weekend. Thank you.
2019 Camaro 1SS M6 Summit White
2018 Camaro 1SS A8 Summit White 2010 Camaro 2SS M6 Inferno Orange Metallic 1998 Camaro Z28 M6 Arctic White 1991 Camaro RS A5 Arctic White 1986 Camaro SC M5 Teal Green 1980 Camaro Z28 M4 Bright Blue |
05-27-2020, 06:22 AM | #7 |
05-27-2020, 06:24 AM | #8 |
Fyi.. the piece that I thought was a air bag sensor was actually the blue tooth microphone. Pop right out
05-27-2020, 06:26 AM | #9 |
Finished product
05-27-2020, 08:00 PM | #10 | |
01-06-2022, 11:37 AM | #11 |
Drives: 18 ZL1 - M6 Join Date: Mar 2019
Hi All,
Does anyone have any links to videos or pics to remove the pillar piece and/or install one of the pillar gauge pods? If so, can you share the links/pics? It looks like I'm gonna need it.. Thanks in advance... |
01-06-2022, 12:43 PM | #12 | |
Honestly, it's just start pulling. You are not going to interfere with that airbag. There is a bungie cord you will have to remove once you get the pillar loosened up. This cord keeps the pillar from going through your face if the airbag does deploy. I have had mine off several times to run wiring for gauges.
01-06-2022, 01:19 PM | #13 | |
So, just pull it straight towards the passenger side? No special tools needed? |
01-06-2022, 01:28 PM | #14 | |
I think I used a trim tool just to get under the edges, but nothing special needed. You'll feel the body clips start to loosen as you pull.
