04-22-2020, 09:24 AM | #1 |
Drives: 2015 V6 Camaro Join Date: Nov 2016
How to fix this BullSh***??
So out of nowhere, my driver side HEADLAMP has
water mist/fog inside of it and my passenger tail light has the same issue...SMH!! Need help/Advice its frustrating knowing that these are NOT aftermarket headlight/Taillight, all original GM parts, but still this happens |
04-22-2020, 09:36 AM | #2 |
Drives: 2013 2SS/RS 1LE (6spd) Join Date: Mar 2018
just a quick question, have you recently changed out bulbs or anything? Maybe the rubber cover wasn't put back on correctly behind the lens? I know that seems juvenile but just what popped into my head. Hope you get it sorted it. Its def annoying to have something like that happen.
CAI intake, Stainless Power LTH, SCT X4, NPP exhaust |
04-22-2020, 09:50 AM | #3 |
Drives: 2015 Camaro Join Date: Aug 2018
Do you "pressure wash" the car by any chance?
04-22-2020, 09:58 AM | #4 |
Drives: 2012 Camaro SS Join Date: Dec 2019
I used to work for a ford dealership and that was a normal problem for many of them. We used to just drill a while to let the water out.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
04-22-2020, 10:07 AM | #5 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Can drill a small hole in the bottom corners. This happens to lots of vehicles.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
04-22-2020, 10:13 AM | #6 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
I agree with the OP. You should NOT have to drill holes in a $30,000+ car!
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
04-22-2020, 10:23 AM | #7 | |
04-22-2020, 10:24 AM | #8 |
04-22-2020, 10:29 AM | #9 |
wow really, I honestly can't drill a hole, its just blows my mind why would we even have to do this with this being GM oem parts........I wonder if the sealant around the headlamp gets old, then allows air/water/moisture inside, but then I think, my car ain't that old , being a 2015.....smh idk....frustrating shit
04-22-2020, 10:32 AM | #10 |
yea I see this can possibly solve the issue, but again why do we need to this?? If GM knew this would happen to there headlamp or tail light, then they should have a drilled hole already there lol
04-22-2020, 10:33 AM | #11 |
04-22-2020, 10:45 AM | #12 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
It’s condensation... have the car sit under the blaring sun, turn your high beams on and call it a day. Happened to my C6Z and my reaction.... meh, it’s water.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
04-22-2020, 11:16 AM | #13 |
I have a 2015 as well and I don't think this is "normal". I haven't had any problems with mine yet and I wash my car a lot with regular hose pressure.
04-22-2020, 11:45 AM | #14 |
It's a defect in the headlamp allowing moisture in. GM covers headlamps during the bumper to bumper coverage. There is a special policy for some of the cadillacs doing it because there was a ton of them. Not so common on the camaro but it's like anything else covered by bumper to bumper, 3 years 36k miles. Just think not too long ago the warranty on new vehicles was 12 months.
