04-21-2020, 01:15 PM | #1 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
ZZP pulleys
I see ZZP SC upper pulley on eBay and it is comparably priced to other pulleys, maybe a little cheaper. Anyone had experience with these?
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
04-29-2020, 06:52 AM | #2 |
Drives: 2013 zl1 vert Join Date: Dec 2018
I do. I have the 2.7 and 2.5. the only problem with them, is if you have a 90mm throttle body the harness plug hits the pulley. you'll have to flip the throttle around.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
04-29-2020, 07:45 AM | #3 |
Valkyrie14
Good to know. Any slippage?
04-29-2020, 07:55 AM | #4 |
No slip. But i have a 9.55 lower so belt wrap is good.
