02-26-2020, 08:03 AM | #1 |
Drives: 2010 Orange 2SS/RS Join Date: May 2010
530WHP NA, need a new fuel pump?
Hello all,
As the title says, anyone have any advice on if this is required or still fine with this power level? |
02-26-2020, 08:14 AM | #2 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
what was the injector duty cycle and fuel pressure when this dyno pull was made?
02-26-2020, 09:01 AM | #3 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
nah you need to adjust fuel pressures in your FPCM. Above 166 LPH or gph it starts to flow less for some reason
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
03-02-2020, 09:24 AM | #4 |
With an N/A build you'll be fine. A bap or an upgrade to a ZL1 pump wouldn't be a bad idea but your pump should hold up.
