02-07-2020, 08:45 AM | #1 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Too loud. Too raspy.
If I could change one thing on my car, it would be the exhaust sound. It's too damn loud for my taste. I prefer a deep rumble that you get from a chambered flowmaster muffler, but I dont want to lose substantial power or create unwanted back pressure.
I have TSP 2 inch headers with 3 bolt flanges welded on. Then I had my exhaust guy Rob, fab up 3 inch piping to a true 3 inch X merge, then 3 inch all the way back to Magnaflow straight through mufflers, 3inch in/out. I can't think of a system that would flow better, besides open headers or cut outs, so any change I make, I will likely lose a few HP. But I'm ok with that if I can quiet it down by a good amount. I fish quite often out of Port Everglades inlet and leaving that house on saturday mornings at 4am is impossible in my car. Looking for recommendations for Mufflers and or resonators (must be true 3inch all the way), to quiet things down. The more quiet the better. Sounds clips would be great.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
02-07-2020, 08:50 AM | #2 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
Magna flow makes a resonated x pipe , has glass mat packing. I would give that a try
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
02-07-2020, 09:04 AM | #3 |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
yup, magnaflow resonated x-pipe will help...the opinion seems to be a 20-30% drop in volume (and less drone, if that's an issue for you). Otherwise you could add hi-flow cats, and switch to borla "touring" mufflers.
NY5thgen.com
02-07-2020, 09:12 AM | #4 |
in 3 inch? Got a link? I cant find it on their website.
02-07-2020, 09:14 AM | #5 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Try bullet resonators
Dynomax has a 3” x pipe muffler but I think it’s pretty long
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
02-07-2020, 09:14 AM | #6 |
02-07-2020, 09:41 AM | #7 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
An option for you might be a more stock exhaust from the header back with cutouts. I have a2.5 catback with borla ataks and it is not too bad once just cruising down the road but it is mighty loud on startup. Once warmed up it idles tame and under light throttle it is tame.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
02-07-2020, 09:45 AM | #8 | |
2010 2SS/RS
02-07-2020, 09:58 AM | #9 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
The magnaflow resonated x pipe that fits in the tunnel is a 2.5” unit about 14” long. I used it once and it does cut volume by 30%. I now have the magnaflow 3” competition catback. I have shorty headers and a stage one cam so the sound is good. I did have hiflows and it was just a bit louder with those. The catback does have a bit of boom and drone, but fabbed up some j pipes and killed the drone and boomy sound from the 3” pipes. Sounds more clear now. And has the deep v8 rumble
02-07-2020, 10:25 AM | #10 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Just turn up the radio
OLD GUY FLYING FAST AND LOW
02-07-2020, 11:16 PM | #11 |
Drives: 2014 Chevy SS Join Date: Nov 2014
Borla.....
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4 2014 Chevy SS --- 429ci Hydraulic Roller LS3 |
02-07-2020, 11:33 PM | #12 |
Drives: 2013 Camaro SS Join Date: Feb 2017
I have the magnaflow competition catback which is a resonated x pipe and straight pipes. Its fairly quiet and has a deep tone. It's pretty loud on cold starts though.
https://youtu.be/gLO9r3T51Fg
2013 Camaro SS
Kooks Headers Vararam DRX 1le Differential 3.91 Bo White throttle body Magnaflow Competition Exhaust 12.391 112 MPH 10/05/19 |
02-08-2020, 08:59 AM | #13 |
Drives: 2010 VR 2SS/RS M6 Camaro Join Date: Feb 2010
I have the 3" Magnaflow resonated X-pipe since I was like you and wanted less restriction. It's a big muffler, doesn't fit with a tunnel brace, and will be your lowest point on your car. I had a 1" drop and I scraped it a lot so I adjusted my coilovers and raised it to like a 3/4" drop and it's much better.
I think if you have a really good exhaust guy you might be able to angle it upwards a bit for more clearance without getting too close to the driveshaft. It does cut down the volume/drone by a good amount though. No regrets. |
02-08-2020, 09:12 AM | #14 |
Also just noticed you've got the longer version linked, there's a 24" version that I have: https://www.magnaflow.com/products/1...rmance-muffler
