dave@hennessey
Old 01-29-2020, 11:26 AM   #1
JGaschCamaro10
JGaschCamaro10's Avatar
Drives: 2010 Camaro SS
CamShafts For Twin Turbo
I just ordered a AGP Twin Turbo Kit with the 3582r GTX Turbos. I want a rough idle CamShaft that is good for Drag Racing. Does anyone have any suggestions on brands or parts?
Running with 1400 cc Fuel Injectors, and a meth kit.
JGaschCamaro10 is offline   Reply With Quote
Old 01-29-2020, 02:58 PM   #2
AGP Turbo
Drives: All things Turbocharged
Brian Tooley Stg4 turbo cam. Good n cheap
AGP Turbo is offline   Reply With Quote
Old 01-29-2020, 06:47 PM   #3
mrimpala02
Drives: Black 2SS RS w/White Stripes
I have a custom TT spec'ed camshaft from Pat G/Cammotion harden core. There are a lot of good choices out there, but recommend spend the extra change for harden core from any dealer.
Also recommend deleting your mufflers better flow and ability to hear the slope better.
3" straight pipes for your listening pleasure:
https://youtu.be/UwpGbzCwUe0
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods |
Installed by Me & Tuned by Pat G
mrimpala02 is offline   Reply With Quote
Old 01-29-2020, 09:12 PM   #4
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I called cam motion and told them what I had and what I wanted out of it. It took about 10 minutes. Cam showed up in 3 days. After install and tune, they nailed exactly what I was looking for.
Old 01-30-2020, 08:21 AM   #5
Omega
Drives: G8
You will most likely be happy with one of the mentioned off the shelf cams, but a custom cam will give you exactly what you ask for.
I also went to PatG/Cam motion. The car drives great and makes good power.
Pat has spec'd the cam for my next engine also. Gives me an idea of how the off the shelf cams stack up
Sent from my Pixel 4 XL using Tapatalk
Omega is offline   Reply With Quote
Old 01-30-2020, 09:09 AM   #6
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
We've got a camshaft developed specifically for the AGP system. We made 1100 WHP on a SBE LSA with this set up. I'd be happy to put a quote together with all of the supporting pieces.
Kind regards,
Jordan Priestley
801-545-4215
JDP Motorsports is offline   Reply With Quote
Old 01-30-2020, 10:47 AM   #7
hillshooter
Drives: 2015 Camaro SS commemorative
this .
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
hillshooter is offline   Reply With Quote
Old 01-30-2020, 11:18 AM   #8
JGaschCamaro10
Kind regards,
Jordan Priestley
801-545-4215
We currently have a 2010 Camaro L99. We have a Magnuson TVS2300 and are looking at AGP Turbo Kits we have decided on Garret BallB 62/62. We need a new cam.
