Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 01-24-2020, 09:33 PM   #1
vincentcamaro
Drives: Camaro SS 2013
Can i use 285s as the front tires on my 13 ss??
vincentcamaro is offline   Reply With Quote
Old 01-24-2020, 09:37 PM   #2
Rons1le
Rons1le's Avatar
Drives: 2015 Camaro 2SS RS 1LE AGM
Yes
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
Rons1le is offline   Reply With Quote
Old 01-25-2020, 05:38 AM   #3
Rich2010
Drives: 2010 Cyber Gray LS3 SS/RS
Depends on what wheels, won’t fit on stock wheels unless they’re 1le or zl1. But yes 285 are the stock tire size on 1le’s and I’m running them on my SS.
2010 Cyber Gray LS3-BTR stage 4-480/428 RXT and 3.91’s
Rich2010 is offline   Reply With Quote
Old 01-25-2020, 05:46 AM   #4
Rons1le
Rons1le's Avatar
SS oem wheels are 20x9 front and 20x10 rear correct? 285s will fit both of those. If they are 20x8 and 20x9s 275s will fit all 4 corners.
Old 01-26-2020, 09:53 AM   #5
ZWA SS
BowtieBelle's SS
ZWA SS's Avatar
Drives: 2010 Camaro SS
Non 1LE are 20x8 and 20x9.
285 would fit the wheel but pooch out. I wonder if it would clear the spring.
ZWA SS is offline   Reply With Quote
Old 01-26-2020, 10:36 AM   #6
Scotty D
Drives: 2014 1le 1SS CRMT
Absolutely you can
I run 295/35/20’s
Scotty D is offline   Reply With Quote
Old 01-26-2020, 10:41 AM   #7
Vegas Bound
Drives: 2013 Sparkly Red One
Not sure, I run 28x5x17 on the front.
Vegas Bound is offline   Reply With Quote
Old 01-27-2020, 12:04 AM   #8
Tomsusername
Tomsusername's Avatar
Drives: Velvet Blue Metallic 2015 1SS 1LE
The answer depends on the wheels. Running a 285 on an 8 inch rim doesn't sit well with me. It'll fit on a 9 inch rim, but it's not exactly ideal. If your talking about a 10 inch rim, do it! You could even pull off a 295 if you want. But it'll all fit under the fender without modification. No worries.
Tomsusername is offline   Reply With Quote
