Old 01-15-2020, 07:33 AM   #1
Espino89
Drives: Camaro ZL1
Header and cam install price.
Got a quote from a local shop to get headers and cam package install with all the supporting mods for the cam and dunk tune. The quote was $6,400 is this to high of a price for this?
Espino89 is offline   Reply With Quote
Old 01-15-2020, 07:44 AM   #2
Techdude99
Techdude99's Avatar
Drives: 2019 Chevy Camaro ZL1 1LE
You'll need to provide more details on the parts.
Techdude99 is offline   Reply With Quote
Old 01-15-2020, 08:19 AM   #3
Espino89
Drives: Camaro ZL1
Parts
Old 01-15-2020, 08:34 AM   #4
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Do you know the brand of headers?
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 01-15-2020, 09:15 AM   #5
Espino89
Drives: Camaro ZL1
I have the headers they are 2” TSP, they are just installing them
Old 01-15-2020, 09:50 AM   #6
IneedAZ
IneedAZ's Avatar
sounds about right since they are pulling the heads it appears. Most cam swaps i have seen posted are in the $5k range parts/labor. But you are getting headers installed and they are pulling the heads. Only part that sounds a little high to me is the Tuning cost.
Old 01-15-2020, 10:09 AM   #7
Kelly@PCMofNC
Drives: 2010 RS/SS
Sounds about right. Labor is going to be high on the Gen V motors, you have to pull the heads to change the lifters and also drop the oil pan (two things you didn't have to do on the cam installs for previous gen ZL1).
Tuning cost seems a little high to me, but if it is a good reputable tuner, then that's fine. The tuning is complicated on these cars also so you want someone who is going to spend the time to get it right. The dyno part is simple it is the driveability that takes so long.
Kelly@PCMofNC is offline   Reply With Quote
Old 01-15-2020, 10:13 AM   #8
Techdude99
Techdude99's Avatar
I agree with the tuning. It should be about half or 2/3's at most.
The rest is average. You're not getting a deal and you're not getting screwed if it's a reputable shop.
Old 01-15-2020, 10:15 AM   #9
Markoz28
Drives: 18 ZL1 nightfall grey A10
Sounds about right. The tuning sounds high but if this is with the 4 credits needed to unlock, dyno tune, and street tune then it’s right. I see you are adding lower pulley to it as well. Might consider going to a 9.17 lower and since the blower is off get it ported and bigger throttle body. Could save a little money by using a soler 95mm instead of a NW 103. Car should make crazy power for maybe 2k more.
Markoz28 is offline   Reply With Quote
Old 01-15-2020, 10:15 AM   #10
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Very good point!
The last thing you want to skimp on is the tune. If that is a very thorough tune, with a lengthy drive street tune included with dyno time, then I wouldn't worry too much. My 5th Gen cam tune cost me $500 from Matt Sorian and he drove it for quite a while while tuning it. I would expect a 6th Gen ZL1 tune to cost more anyway.
OP, good luck on the build. It is exactly what I would do if I was lucky enough to have a ZL1.
Old 01-15-2020, 10:16 AM   #11
JasonSB
Drives: 2018 ZL1
What year is your car? If 17 or 18 I would have them replace the oil pump while in there.
2018 ZL1 A10 - Rotofab Intake, LT5 TB, TSP Headers, ATI Balancer, 9.1 Lower Pulley, JMS BAP, Flex Fuel.
JasonSB is offline   Reply With Quote
Old 01-15-2020, 10:26 AM   #12
Espino89
Drives: Camaro ZL1
It’s a 18, and why go with a 9.17 lower?
Old 01-15-2020, 10:31 AM   #13
JasonSB
Drives: 2018 ZL1
9.1 lower will give you 2 more lbs of boost. They have to remove the balancer to do the cam so it wouldnt cost any more in labor to do the 9.1. It will add $600 to the cost though
Old 01-15-2020, 11:48 AM   #14
Markoz28
It will not cost more than what is already quoted since the ATI damper and 9.06” pulley are on the bill now. You will only need to go with the 9.17 rather than the 9.06”.
