01-02-2020, 12:15 PM | #1 |
Drives: 2017 Camaro SS Convertible Join Date: Jul 2019
Qtr Window Wind Noise
Lets hope i het more responses with information then i have looking for black leather knee pads. I started hearing noise coming between the main window and my qtr window. Vehile is still under warranty brought it up when other work was getting done and they just seemed to ignore it. It can be heard coming from both sides i notices part of the seal is flattened is that normal on these? Can all who read just respond with if you have the noise and if you seal on the qtr window as this weird bend to it.
01-02-2020, 06:06 PM | #2 |
Seriously it takes just a few seconds to look and post. Please help me out here.
01-02-2020, 09:58 PM | #3 |
Yours definitely has more wear in than mine. Regardless, both Gen 6 Verts I’ve owned have a mild wind noise (from that general area) at speeds over 60MPH. I don’t worry about it since I almost entirely drive with the top down.
01-02-2020, 10:20 PM | #4 |
Thank you so much for the reply.
01-02-2020, 11:49 PM | #5 |
Drives: 2020 2ss vert Join Date: Oct 2019
My owners manual states "The rear windows should always be raised before the front windows to ensure the best seal."
Don't know if you are doing this or not, but it may or may not help your situation. Last edited by Ron2ss; 01-02-2020 at 11:59 PM. Reason: sp |
01-12-2020, 08:41 PM | #6 |
Drives: 2017 50th Anniversary Convertible Join Date: Feb 2012
Yes I have some wind noise as well there. I had the dealer check it out and they said yes it has some woind noise but is normal for the convertible. I didn't like the answer but I also drive top down whenever possible so I let it go. My rubber seal looks the same as the above picture.
Sent from my SM-G950U using Tapatalk
2017 2LT 50th Anniversary Edition Conv. TPW 9/26
01-12-2020, 09:05 PM | #7 |
https://www.google.com/url?sa=t&sour...91YLNGkA83lR0j
Dealer is trying this we shall see if it works |
01-12-2020, 11:04 PM | #8 |
Drives: Chevy Camaro 2SS Join Date: Aug 2019
I've only noticed complaints about wind noise on the vert threads but enough people here mention it to be a "feature" rather than an fault. Honestly in all 3 of my verts I've always had wind noise, even in the folding hard top so think it's just one of the joy's of owning a vert. Read some of the threads on seal care, I've used some good products and certainly feel they reduce the noise to something bearable. If it's super bad your window might be out of alignment with is a dealer fix.
01-13-2020, 09:17 AM | #9 | |
03-26-2020, 09:42 PM | #10 |
Treasure Coast Camaro 5
Drives: 19 2SS vert, Mosaic Blk, A10 Join Date: Feb 2009
I notice it significantly more in my 19 than I had in my previous 11... But like most others, tops rarely up so I don't mind
