10-13-2019, 12:40 PM | #1 |
Drives: 2017 Hyper Blue SS Join Date: Jul 2017
Caliper bolt help!
Hi everyone, My car needs new brakes, easy enough right? so I ordered the parts, pads and rotors.
went to install them this morning, got the pins out and the bracket that hold the pads out, got the pads out, all is going well so far, go to take the caliper bolts out, and they're tough, get the breaker bar, the bottom one starts to loosen off a bit, but its fighting me the whole time, even after I've gotten it about 1/2in-3/4 backed out, now it wont even budge, not even with an impact. anyone else have experience with these bolts? are they hard to remove? do i need a stronger impact? the one I'm using is supposed to be rated at 240FT-lb but it doesn't fit so I'm using an adapter and maybe that's causing it to lose power. any help would be greatly appreciated! thank you. |
10-13-2019, 02:19 PM | #2 |
Drives: Chevy Camaro Join Date: Jul 2019
Sounds cross threaded, try lube, cause everything is better with a lil lube,
10-13-2019, 04:08 PM | #3 |
Drives: 2016 Nightfall Metallic Grey 2ss Join Date: Oct 2017
They're blue or orange loctited from the factory, put down your purse and loosen the bolts.
10-13-2019, 04:09 PM | #4 |
Crossed or plain galling. Short answer its F'd. Try heat but good chance you'll break it off.
10-13-2019, 04:27 PM | #5 |
Drives: '17 Red Hot 2SS 6MT Join Date: Mar 2018
Mine were very hard to get off as well. It's the factory loctite. They came out halfway then stopped. Maxed out the impact gun and they came out though.
10-13-2019, 05:09 PM | #6 |
This is what I'm hoping for, I think my gun isn't strong enough, especially with the old rusted angle adapter I have.
10-13-2019, 05:25 PM | #7 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
My question is, are you upgrading the brakes with better rotors? Why not turn them if it's your first brake job.
10-13-2019, 05:48 PM | #8 |
10-13-2019, 07:24 PM | #9 | |
Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
Nigel |
10-13-2019, 08:24 PM | #10 |
Thanks for the advice! I'll hit it with some heat, and make sure I'm using an impact socket.
10-13-2019, 09:32 PM | #11 |
That's not how an impact socket works, if anything you want a chrome socket because it transfers more force. That's why you aren't supposed to torque anything with impact sockets and that's why impact sockets are cheaper. They are softer.
10-13-2019, 09:43 PM | #12 | |
Drives: 2017 50th Anniversary Camaro SS Join Date: Jun 2017
You are wrong! Impact sockets are less hard and absorb blows. You can think of impact sockets as being designed to withstand significant jolts of power, whereas chrome sockets are made for hand torque applied (much slower and more consistent). Chrome sockets should never be used on high-torque impact guns or wrenches. This is a quote from agradetools.com
2017 50th Anniversary Camaro 2SS
2016 Chevy Malibu LT (wife's car) 2004 Chevy Impala (winter car) 2001 Chevy Camaro SS (sold) 1969 Chevy Suburban (restoration project) |
10-14-2019, 08:04 AM | #13 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Turn your compressor wide open and use your impact gun to run the bolts back in then alternate between loosening and tightening to break up the factory thread locker and you should be able to coax them out.
Baby Blue
10-14-2019, 08:28 AM | #14 |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
Doubt OP's impact wrench is an air tool if it's only rated for 240 ft/lb
May need a higher rated one. My son bought a cheap Harbor Freight impact wrench rated for 230 ft/lb, was pretty much worthless. Even my cordless Kobalt one is rated for more than 600 ft/lb |
