Roto-Fab
Old 08-11-2019, 12:59 PM   #1
6spdLs3
6spdLs3's Avatar
Drives: 2011 camaro ss
Powermaster 9509 starter 2011 LS3
I tried installing this in my 2011 SS but the stock starter has a plug in solenoid wire and this one is a conventional nut bolt style.
Anyone have experience with this? Is there a pigtail that can be purchased so the original wire doesn't have to be cut?
Thanks
6spdLs3 is offline   Reply With Quote
Old 08-11-2019, 02:57 PM   #2
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I installed the same starter on my ZR1. I just cut the OEM end off and crimped on a ring.
A more labor intensive option is to make a female plug that matches the OEM and install the ring on the other end. Then you would just plug the two in together.
The easiest thing to do is cut the OEM one off, leaving enough wire in case you ever wanted to put it back together.
Old 08-11-2019, 05:44 PM   #3
6spdLs3
6spdLs3's Avatar
Yea, I was trying to avoid cutting the connector off. Might have to splice into it if I can't find the proper end.
Old 08-12-2019, 07:09 PM   #4
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
The stock end is garbage anyway and prone to not connect well... also the starter has to be clocked and the main power wire bent to connect to the starter. You need to clear the sensor that comes out the side of the pan.....
christianchevell is offline   Reply With Quote
Old 08-18-2019, 12:51 PM   #5
6spdLs3
6spdLs3's Avatar
I was able to source an oem connector with a pigtail to connect to the solenoid. You are correct on clocking the starter to clear the sensor on the block. Also the original heat shield won't work and neither will the small plastic flywheel shield.
After these hurdles the starter does work great and I'm no longer getting slow cranking with the occasional service stabilitrak.
Old 08-18-2019, 12:59 PM   #6
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Can you share where you sourced the OEM pigtail connector? Thanks.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come.
Black_SS10 is offline   Reply With Quote
Old 08-18-2019, 01:38 PM   #7
6spdLs3
6spdLs3's Avatar
Yep, I bought it from EFI Connection, I had them make it with 6" pigtail - Link below shows the part without the pigtail.
https://www.eficonnection.com/home/S...ssSearchForm=+
EFI Connection, LLC
Email: help@eficonnection.com
Website: eficonnection.com
Old 08-18-2019, 03:11 PM   #8
Black_SS10
SomeguyK
Black_SS10's Avatar
EFI Connection, LLC
Thank you!
More to come.
Old 08-18-2019, 08:33 PM   #9
6spdLs3
6spdLs3's Avatar
Old 08-19-2019, 06:56 AM   #10
christianchevell
Well that's one big connector...LOL But glad you tried the starter so you could report as I have it solves hot starting problems...…..
Old 08-19-2019, 09:38 PM   #11
6spdLs3
6spdLs3's Avatar
It's actually a pleasure to click the starter switch now ☺️
Old 09-07-2019, 09:39 AM   #12
christianchevell
Thank you for your feedback...…. others may read this.....
Old 09-07-2019, 10:21 AM   #13
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Link doesn't work.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 04-09-2020, 03:51 PM   #14
Splat
Splat's Avatar
Drives: 2012 1SS M6 IOM
Just a update on the EFI wire.
In the search box, just type in "starter", and scroll down.
here is the link
https://www.eficonnection.com/home/p...rters-6-inches
2012 1SS Camaro LS3 Inferno Orange
Mods: LSA Supercharger, 2.55 Pulley, Custom Boost Cam, ARH LTH 1 7/8, HFC, 3' Magnaflow Exhaust, JLT CAI, Elite CC V2, BO White Stage 2 TB, GM 3.91 Gears, DSS CF Driveshaft, BMR Bushing Kit.... . Tuned by JTM Motorsports 540 Hp 550Tq on 9PSI
Axles, Monster Clutch, Hotchkis TVS Track Pack kit.......For 2018.
Splat is offline   Reply With Quote
