08-04-2019, 12:27 PM | #1 |
Drives: 2014 corvette Join Date: Oct 2016
Iat2 getting to high still.
So far setup is
2013 zl1 A6 Id1050x injectors Jms bap 2.45 upper 9.06 lower dsx bigger idler Gp2.5 cam plus springs/pushrods and so on K&N carbon fiber intake Tsp headers No cats Corsa exhaust Afco heat exchanger external reservoir reinforced brick Catch can Ngauge Aem obd2 wideband Fully tuned by "Mark Bridges" Outside temp 88f I cruise iat1 87f Iat2 is 97f If I do a second gear pull from 40mph till top of 3rd gear. I will get to almost 170f+ iat2. Cool down is very quick. But still ?? That's hot. Last edited by curtmgulla; 08-04-2019 at 02:26 PM. |
08-04-2019, 01:12 PM | #2 | |
Drives: 2014 Summit White ZL1 Join Date: Oct 2018
What kind of mixture do you have for your HX? Coolant wise.
2014 Summit White ZL1- Manual
08-04-2019, 01:32 PM | #3 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
Reservoir?
I have a similar setup (9.17 lower), stroked LSA but, I have more capacity, 3 HXs in parallel, dual intercooler pumps, brick re-enforced, and before meth - max I saw on a road course was 169°. I run E85 however; that does not cool IAT temps - just combustion temps. With meth on a WOT pull, Mark and I saw ~135° IAT2 temps so that really helped. With E85, I don’t start pulling timing until IAT2 hits 175°. This is all with ambient temps in the mid 90s. Ask Mark about my setup ;o) -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
08-04-2019, 01:40 PM | #4 |
Here are some examples:
https://www.camaro5.com/forums/showp...postcount=2207 https://www.camaro5.com/forums/showp...postcount=2234 Before meth, similar configuration (it was 95° out but ambient was not correct from OBD2): https://www.camaro5.com/forums/showp...postcount=2235 -Don
747 RWHP 794 RWTQ
08-04-2019, 02:21 PM | #5 |
sorry yes I do have reservoir and yes brick was reinforced..
cant do e85 right now.. mark was telling me about emp pump. coolant is just 50/50 mix dexcool also 14.5 to 15psi boost |
08-04-2019, 02:50 PM | #6 |
I'm at 90/10 for coolant mix but, I'm in Texas. Flow, mix, and capacity helped first but, I'm really spinning the blower so, added meth and E85 to help...
So does the 5" CAI and NW 102... -Don
747 RWHP 794 RWTQ
08-04-2019, 07:00 PM | #7 |
Drives: 2015 ZL1 Join Date: May 2015
i have a 10" lower and stock upper with res. and stock HX and pump with e 85 i also use engine ice coolent in my inner cooler 1st through 2nd pull i see around 140 to 145 iat2 on a 85 degree day...
08-05-2019, 06:47 AM | #8 | |
So should I drop the antifreeze content to like 25/75 and add a water wetter /engine ice. Additive? |
08-05-2019, 09:14 AM | #9 |
Well, depends on how cold it gets where you are. If you’re ok changing out the fluid multiple times a year then yes.
Here is the ratio chart I use: https://www.camaro5.com/forums/showp...&postcount=709 -Don
747 RWHP 794 RWTQ
08-06-2019, 02:18 PM | #10 |
BURN RUBBER NOT YOUR SOUL
Drives: 2013 ZL1 M6 Blue Ray Join Date: Jun 2017
Dam you might have a problem with your brick, even tho it's reinforced. You see my setup in signature. If I do mid 3rd to top of 4th I'll reach about 140 iat2.
Mods-Kong Ported Blower, ID1700X injectors, 2.35/8.65, TSP Ported Heads, Custom Grind Cam, RPM 5 inch Intake, NW 102mm, Kooks 1 7/8, Corsa Extreme, Afco Heat Exchanger, PNR 4 gal ice tank/EMP pump, Oil catch can, Thermal reduction plates, BR7EF plugs, DSX Aux Pump, Monster LT1-S triple. 788hp/757tq-93, 839hp/785tq-E85. Burn Rubber Not Your Soul
08-07-2019, 09:48 AM | #11 |
Shred Till I'm Dead
Drives: 2013 ZL1 Summit White Join Date: Aug 2016
How accurate would the reading be for the IAT2 on a Dashlogic? Mine is showing anywhere from 175-185 under just normal driving with a reinforced brick and the mods in my signature. Doesn't seem right to me, it is rather hot in Central Texas this week (105 heat index).
2013 Summit White ZL1 W/Recaros
Mods: Roto-Fab CAI, Stainless Works 3" Exhaust, 1-7/8" Stainless Works LT Headers, 2.55 Griptec Upper, Metco Damper, 9.1" Metco Lower Ring, Metco Solid Isolator, Metco Idler Relocation Bracket/50mm Idler, Texas Speed Heads/Pushrods/Springs/Retainers/SS Valves/Custom Grind Cam, ARP Bolt Kit, DMS Auxiliary Fuel Pump Kit With Flex Fuel Sensor, ID1300 Injectors, Lingenfelter Dual Fan HX, Lingenfelter 160 Degree Thermostat, DMS Expansion Tank Tuned By Matt at Dedicated Motorsports - 750whp on E85 - Mainline Hub Dyno |
08-07-2019, 11:32 AM | #12 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Should be accurate. Either your pump isn't working, or there is air in your system.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // Elite Ultra CC // BMR MM
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
08-07-2019, 02:13 PM | #13 |
Shred Till I'm Dead
Went and took a look at it on my lunch break and my expansion tank was bone dry, still heard the pump try to do its duty but it cuts off. Guess I need to check that a little more often. :(
08-09-2019, 09:54 AM | #14 |
Shred Till I'm Dead
Update: I was pretty sure I had a serious issue, possible leaking IC brick leaking coolant into the blower and possibly the engine. Pulled the lid, flipped it over and filled it with water plugged the outlet hole and sprayed compressed air into the inlet and saw no bubbles come up.
The lid/brick had a lot of water in it of which I never put in, it has always had Dexcool in the expansion tank. No idea how that happened. Cleaned everything up really good, put it back together and filled it with Dexcool again, and the IAT2's have been around 95-105 on normal driving in the morning. Around 120-130 in the middle of the afternoon after a handful of hot starts in 102 degree weather. I would definitely check that brick for leaks though, it's a known issue with that terrible design and it could possibly lead to a dropped valve. Even if it has been reinforced they are still prone to it from what DMS has told me.
